Hi Nordic,
In my application, I want to consume as less power as I can. In the initialization I have this functions:
static void utils_setup(void)
APP_TIMER_INIT(APP_TIMER_PRESCALER, APP_TIMER_OP_QUEUE_SIZE, false);
static void softdevice_setup(void)
uint32_t err_code;
err_code = softdevice_ant_evt_handler_set(ant_evt_dispatch);
//angel start
err_code = softdevice_sys_evt_handler_set(sys_evt_dispatch); // start the interrupt sys controller
//angel end
err_code = softdevice_handler_init(NRF_CLOCK_LFCLKSRC, NULL, 0, NULL);
err_code = ant_stack_static_config();
void configure_pins_input()
ret_code_t err_code;
nrf_drv_gpiote_in_config_t in_config = GPIOTE_CONFIG_IN_SENSE_TOGGLE(true);
in_config.pull = NRF_GPIO_PIN_NOPULL;
// down_pin
err_code = nrf_drv_gpiote_in_init(buttons.up.input_pin, &in_config, in_up_pin_handler);
nrf_drv_gpiote_in_event_enable(buttons.up.input_pin, true);
// down pin
err_code = nrf_drv_gpiote_in_init(buttons.down.input_pin, &in_config, in_down_pin_handler);
nrf_drv_gpiote_in_event_enable(buttons.down.input_pin, true);
// left_pin
err_code = nrf_drv_gpiote_in_init(buttons.left.input_pin, &in_config, in_left_pin_handler);
nrf_drv_gpiote_in_event_enable(buttons.left.input_pin, true);
// left_pin
err_code = nrf_drv_gpiote_in_init(buttons.right.input_pin, &in_config, in_right_pin_handler);
nrf_drv_gpiote_in_event_enable(buttons.right.input_pin, true);
void configure_pins_output(void)
nrf_gpio_cfg_output(LED_UP);
nrf_gpio_cfg_output(LED_LEFT);
nrf_gpio_cfg_output(LED_RIGHT);
nrf_gpio_cfg_output(LED_DOWN);
nrf_gpio_pin_set(LED_UP);
nrf_gpio_pin_set(LED_LEFT);
nrf_gpio_pin_set(LED_RIGHT);
nrf_gpio_pin_set(LED_DOWN);
static void timer2_init()
NVIC_EnableIRQ(TIMER2_IRQn);
NVIC_SetPriority(TIMER2_IRQn, NRF_APP_PRIORITY_LOW);
NRF_TIMER2->TASKS_STOP = 1;
NRF_TIMER2->MODE = TIMER_MODE_MODE_Timer;
NRF_TIMER2->PRESCALER = 4; // Fhck / 2^4
const uint32_t PRESCALER_VALUE = 100;
NRF_TIMER2->CC[0] = PRESCALER_VALUE & 0xFFFF; // 10000 - 10ms
NRF_TIMER2->BITMODE = (TIMER_BITMODE_BITMODE_16Bit << TIMER_BITMODE_BITMODE_Pos);
NRF_TIMER2->TASKS_CLEAR = 1;
NRF_TIMER2->INTENSET = (TIMER_INTENSET_COMPARE0_Enabled << TIMER_INTENSET_COMPARE0_Pos);
NRF_TIMER2->EVENTS_COMPARE[0] = 0;
// start timer
NRF_TIMER2->TASKS_START = 1;
After this, I open a channel, start doing things and after a while, go to sleep. To go to sleep, what I do is: I close the channel I just opened, I turn OFF the timer and I turn OFF the LEDs. Still the power consumption is around 1 mA, which is totally too much. I think that the main problem comes from the fact that the pins are set as output, and they are letting some current go out. Do you know in which set up I should put the pins before going to sleep?
Thanks!
PS: nRF51422, ANT, S210 v5.0.0
