I'm writing a firmware, with SD130, using mbed libraries.
Firmware used to run fine. I added a new object, and now, when connecting, it hardfaults. I put a breakpoint in the connection callback, this breakpoint is never reached.
The object I added is a RamStorageManager.
Here's a code excerpt:
class RamStorageManager : public StorageManager
protected:
static const uint32_t UserEntries = 2;
static const uint32_t EventEntries = 2;
// Begin
Otp OTP;
Information Information;
Event events[EventEntries];
User users[UserEntries];
// End
Now, if I comment the code between "begin" and "end", everything works fine. Note, the object is a global variable, statically allocated:
RamStorageManager storageManager;
It is actually currently unused (a reference to is is passed to another object, which stores it and doesn't use it). The object doesn't have code anymore (all methods are just "return false", but they are anyway never called).
As far as I know, my object should be stored in global memory, at an offset statically allocated at compile time. It should not affect the heap.
So my wonder is: why do I get a hardfault when my object gets bigger?!
