Hi, I have a problem that when formatting an uSDcard from ext4 to fat32 it gets with both file systems.
- In my code I use the FAT FS library [http://elm-chan.org/fsw/ff/00index_e.html] and the nordic 12.2.0 SDK [http://infocenter.nordicsemi.com/index.jsp?topic=%2Fcom.nordic.infocenter.sdk5.v12.2.0%2Findex.html].
The purpose of my code is to use SD card with any content, I always format the SDCard when starting the code..
I did several tests with the support of the gparted tool:
Test 1:
- Ensure with gparted that the sd card is empty (If there is any partition select it and delete it)
- Run my code
- Insert the sd card into the pc verify that the filesystem is a fat32 and that all the desired files were created.
Test 3: 1.With gparted remove the fat32 partition (select the partition and delete it) and create a new with fat16 filesystem with 4gb (New->Partition) 2. Run my code 3. Insert the sd card into the pc verify that the filesystem is a fat32 and that all the desired files were created.
Test 4: 1.With gparted remove the fat32 partition (select the partition and delete it) and create a new with ext4 filesystem with max size (New->Partition) 2. Run my code 3. Insert the sd card into the pc verify that the filesystem is a fat32 and that all the desired files were created.
Test 5: 1.With gparted remove the fat32 partition (select the partition and delete it) and create a new with ntfs filesystem with max size (New->Partition) 2. Run my code 3. Insert the sd card into the pc verify that the filesystem is a fat32 and that all the desired files were created.
Test 6: 1.With gparted format the current partition to one of type fat 16 (select the partition and choose format to... -> fat16) 2. Run my code 3. Insert the sd card into the pc verify that the filesystem is a fat32 and that all the desired files were created.
Test 7: 1.With gparted format the current partition to one of type ntfs (select the partition and choose format to... -> ntfs) 2. Run my code 3. Insert the sd card into the pc verify that the filesystem is a fat32 and that all the desired files were created.
Test 8: 1.With gparted remove the fat32 partition (select the partition and delete it) and create a new with fat32 filesystem with max size (New->Partition). After created format the partition to one of type ext4 (select the partition and choose format to... -> fat32) 2. Run my code 3. Insert the sd card into the pc verify that the filesystem is a fat32 and that all the desired files were created.
Test 9: 1.With gparted format the current partition to one of type ext4 (select the partition and choose format to... -> ext4) 2. Run my code 3. When I insert the file system is not recognized if I run the command: $mount /dev/{device} I verified the existence of more than one file system. I need to run the command mount -t vfat /dev/{device} to ru the fat32 filesystem and see the files created by my code. -To recover the sdcard I need to delete the two file systems created with the command: sudo dd bs=512 count=100 if=/dev/zero of=/dev/{device}
Steps to format and create the fat32 filesystem:
/* Partition table must be initialized by the user */
PARTITION VolToPart[] = {0}; /* "0:" ==> Physical drive 0, 1st partition */
/* Use a total size of a single partition */
DWORD plist[] = {100};
/* Maximum working area 512 bytes */
BYTE work[_MAX_SS];
/* Creating a partition */
f_fdisk(0, plist, &work);
/* Creating FAT32 file system */
create_fs_result = f_mkfs(DEFAULT_DRIVE, FM_FAT32, DEFAULT_ALLOCATION_UNIT_SIZE, work, sizeof(work));
