SWI user flags
Hello to all nordic jedi masters out there!
I am using nRF SDK v11.0 with the nRF52832.
I am a little bit confused about the usage/meaning of the flag argument in the nrf_drv_swi_trigger function.
Is it an arbitrary "context" variable I can use with any unsigned integer value? If so, then I have noticed that nrf_swi_flags_t is an alias for uint16_t but the flag argument of nrf_drv_swi_trigger is of uint8_t type.
Let me piggyback another question. I am using SD13.2 and the app_timer library. In order for me to use a SWI in my application, is it sufficient to define SWI_DISABLE0? If I don't, I get the error: "Symbol SWI0_EGU0_IRQHandler multiply defined (by app_timer.o and nrf_drv_swi.o)".
Thank you!
    Yes, the flags are arbitrary "context" variable, it allows users to pass extra flags to SWI interrupt handler functions. Looks like nrf_swi_flags_t should have been a uint8_t. Regarding the SWI0_EGU0_IRQHandler symbol error, in SDK 11 app_timer uses SWI0_EGU0_IRQn, but you can change it to use SWI1_EGU1_IRQn instead. You can change this in app_timer.c :
    #elif defined NRF52
    #define SWI_IRQn SWI1_EGU1_IRQn
    #define SWI_IRQHandler SWI1_EGU1_IRQHandler
    Regarding SWI_DISABLE0 you can read here that:
    To disable specific SWIs from the pool, add a global define during compilation (SWI_DISABLE0 to SWI_DISABLE5). Any disabled SWI will not be allocated and will therefore not be available to the user.
