I'm trying to use the command "mlme_start_req" to setup the device as a pan coordinator to send beacons to the others devices in the network, but after submit the command the callback is not called. For instance, if I don't set a short address before the start the callback is called with the error code 153 (should be the 236, based on the struct mac_status_t), this means that the callback is working but only when something is wrong.
This is the start request:
static void a_start(void * p_data)
mlme_start_req_t startReq =
.pan_id = 0x1234,
.logical_channel = 17,
.start_time = 0x000000,
.beacon_order = 0,
.superframe_order = 0,
.pan_coordinator = true,
.battery_life_extension = false,
.coord_realignment = false,
mlme_start_req( &startReq, mlme_start_conf);
This is the call back:
static void mlme_start_conf(mlme_start_conf_t * conf)
fsm_event_data_t data =
.m_start_conf = conf,
fsm_event_post(E_START_DONE, &data);
Anyone have idea of what is happening?
Regards, Jose
