Hello.
Due to expanding code size because of the peer manager i m forced to move to gcc and Eclipse. So far according to the tutorial i`m proceeding fine.
But, after importing my project into eclipse it turned out that my project compiles, but the target is not built because it does not generate the nrf52832_xxaa.o
Linking target: _build/nrf52832_xxaa.out "C:/Program Files (x86)/GNU Tools ARM Embedded/6 2017-q1-update/bin/arm-none-eabi-gcc" -Wl,-Map=_build/nrf52832_xxaa.map -mthumb -mabi=aapcs -L ../../../../../../components/toolchain/gcc -Tble_app_uart_gcc_nrf52.ld -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -Wl,--gc-sections --specs=nano.specs -lc -lnosys @_build/nrf52832_xxaa.in -lm -o _build/nrf52832_xxaa.out arm-none-eabi-gcc: error: build/nrf52832_xxaa.o: No such file or directory ../../../../../../components/toolchain/gcc/Makefile.common:153: recipe for target '_build/nrf52832_xxaa.out' failed make: *** [_build/nrf52832_xxaa.out] Error 1
when i "make" via command line, it returns the same, so i think it is not related to eclipse. However untouched examples all built fine, so i guess it is something related to my project.
I started from the peripheral uart example. I added a new service which i put in /components/sources. This i included in the makefile, and also removedthe -Werror option because i have left some unused variables. The rest is according to the tutorial. How come nrf52832_xxaa.o is not generated but all others?
