Why is power consumption so high in system off? (not debug)
I am aware that the debugging interface draws significant current, I do not believe that is the case.
I have 2 designs in front of me. Let's call them '2.0' and '3.3' (their HW revision #s). Both are machine assembled. I am running the SDK's 'ble_app_template' program modified as shown below:
/**@brief Function for application main entry.
  int i = 0;
  for (i = 0; i < 10000; i++)
  NRF_POWER->SYSTEMOFF = 1;
// Initialize
leds_init();
timers_init();
gpiote_init();
buttons_init();
ble_stack_init();
You will see that after a short delay I enter system off. '2.0' is a nRF51822-QFAB A0 programmed with S110 5.x, '3.3' is a nRF51822-QFAB B0 programmed with S110 6.0.0
I load this code onto both designs. On '2.0' I measure 1.2 microamperes of supply current @ 3.0 volts. On '3.3' I measure ~470 microamperes at 3.0 volts.
Since we all know '2.0' is fine I will not attach design documents. The significant difference is the silicon revision and it is using the STM balun.
I've attached a screenshot of the schematic. (the site notes that I must have 10 points to upload files, please give me some points :))
Update: Through removing/reworking various components I am growing more and more confident that this is an issue with my circuit board assembly. Will update when the culprit is found.
