Im trying to monitor the high voltage im generating with PWN using ADC. I also need to run BLE at the same time to provide results. So far I dont have any luck and it seems with Keil you cant even debug this things (please correct me if Im wrong, but when i start stepping through it gets hang on the first BLE command).
Im using ble_hrs example. And thats what i added:
//ADC initialization
static void adc_init(void)
/* Enable interrupt on ADC sample ready event*/
NRF_ADC->INTENSET = ADC_INTENSET_END_Msk;
sd_nvic_SetPriority(ADC_IRQn, NRF_APP_PRIORITY_LOW);
sd_nvic_EnableIRQ(ADC_IRQn);
NRF_ADC->CONFIG = (ADC_CONFIG_EXTREFSEL_None << ADC_CONFIG_EXTREFSEL_Pos) /* Bits 17..16 : ADC external reference pin selection. */
| (ADC_CONFIG_PSEL_AnalogInput1 << ADC_CONFIG_PSEL_Pos) /*!< Use analog input 2 as analog input. */
| (ADC_CONFIG_REFSEL_VBG << ADC_CONFIG_REFSEL_Pos) /*!< Use internal 1.2V bandgap voltage as reference for conversion. */
| (ADC_CONFIG_INPSEL_AnalogInputOneThirdPrescaling << ADC_CONFIG_INPSEL_Pos) /*!< Analog input specified by PSEL with no prescaling used as input for the conversion. */
| (ADC_CONFIG_RES_8bit << ADC_CONFIG_RES_Pos); /*!< 8bit ADC resolution. */
/* Enable ADC*/
NRF_ADC->ENABLE = ADC_ENABLE_ENABLE_Enabled;
/* Interrupt handler for ADC data ready event */
void ADC_IRQHandler(void)
/* Clear dataready event */
NRF_ADC->EVENTS_END = 0;
/* Write ADC result to port 2 */
//nrf_gpio_port_write(NRF_GPIO_PORT_SELECT_PORT2, NRF_ADC->RESULT);
//nrf_gpio_pin_toggle(LED_3);
ADCLEVEL=NRF_ADC->RESULT;
//Use the STOP task to save current. Workaround for PAN_028 rev1.5 anomaly 1.
NRF_ADC->TASKS_STOP = 1;
//Release the external crystal
//sd_clock_hfclk_release();
I also enable conversion on every battery timer expiration
NRF_ADC->EVENTS_END = 0; // Stop any running conversions.
NRF_ADC->TASKS_START = 1;
and eventually write the ADCLEVEL value in the battery level on ble.
battery_level=ADCLEVEL;
err_code = ble_bas_battery_level_update(&m_bas, battery_level);
Any idea what am i doing wrong and how i can test/debug this?
Thanks!
