Hello, We are migrating from IAR 760 to IAR 8.10 compiler does not produce the same assembly for the SDK12 inline function nrf_delay_us. The original C Function is :
__STATIC_INLINE void nrf_delay_us(uint32_t number_of_us) {
const uint32_t clock16MHz = CLOCK_FREQ_16MHz;
if (number_of_us)
__ASM volatile (
#if ( defined(__GNUC__) && (__CORTEX_M == (0x00U) ) )
".syntax unified\n"
"1:\n"
" NOP\n"
" NOP\n"
" NOP\n"
" NOP\n"
" NOP\n"
" NOP\n"
" NOP\n"
" NOP\n"
" CMP %[SystemCoreClock],%[clock16MHz]\n"
" BEQ.n 2f\n"
" NOP\n"
#if defined(NRF52) || defined(NRF52840_XXAA) || defined(NRF52832)
" NOP\n"
" NOP\n"
" NOP\n"
" NOP\n"
" NOP\n"
" NOP\n"
" NOP\n"
" NOP\n"
" NOP\n"
" NOP\n"
" NOP\n"
" NOP\n"
" NOP\n"
" NOP\n"
" NOP\n"
" NOP\n"
" NOP\n"
" NOP\n"
" NOP\n"
" NOP\n"
" NOP\n"
" NOP\n"
" NOP\n"
" NOP\n"
" NOP\n"
" NOP\n"
" NOP\n"
" NOP\n"
" NOP\n"
" NOP\n"
" NOP\n"
" NOP\n"
" NOP\n"
" NOP\n"
" NOP\n"
" NOP\n"
" NOP\n"
" NOP\n"
" NOP\n"
" NOP\n"
" NOP\n"
" NOP\n"
" NOP\n"
" NOP\n"
" NOP\n"
" NOP\n"
" NOP\n"
"2:\n"
" SUBS %0, %0, #1\n"
" BNE.n 1b\n"
#if __CORTEX_M == (0x00U)
#ifdef __GNUC__
".syntax divided\n"
:"+l" (number_of_us) :
#else
:"+r" (number_of_us) :
[SystemCoreClock] "r" (SystemCoreClock),
[clock16MHz] "r" (clock16MHz)
#ifdef __ICCARM__
__DMB();
The assembler generated by IAR 7.60 is :
0x1ffda: 0x4a39 LDR.N R2, [PC, #0xe4] ; 0xf42400 (16000000)
0x1ffdc: 0x6008 STR R0, [R1]
0x1ffde: 0x202f MOVS R0, #47 ; 0x2f
0x1ffe0: 0x4936 LDR.N R1, [PC, #0xd8] ; SystemCoreClock
0x1ffe2: 0x6809 LDR R1, [R1]
0x1ffe4: 0xbf00 NOP
0x1ffe6: 0xbf00 NOP
0x1ffe8: 0xbf00 NOP
0x1ffea: 0xbf00 NOP
0x1ffec: 0xbf00 NOP
0x1ffee: 0xbf00 NOP
0x1fff0: 0xbf00 NOP
0x1fff2: 0xbf00 NOP
0x1fff4: 0x4291 CMP R1, R2
0x1fff6: 0xd02f BEQ.N 0x20058
0x1fff8: 0xbf00 NOP
0x1fffa: 0xbf00 NOP
0x1fffc: 0xbf00 NOP
0x1fffe: 0xbf00 NOP
0x20000: 0xbf00 NOP
0x20002: 0xbf00 NOP
0x20004: 0xbf00 NOP
0x20006: 0xbf00 NOP
0x20008: 0xbf00 NOP
0x2000a: 0xbf00 NOP
0x2000c: 0xbf00 NOP
0x2000e: 0xbf00 NOP
0x20010: 0xbf00 NOP
0x20012: 0xbf00 NOP
0x20014: 0xbf00 NOP
0x20016: 0xbf00 NOP
0x20018: 0xbf00 NOP
0x2001a: 0xbf00 NOP
0x2001c: 0xbf00 NOP
0x2001e: 0xbf00 NOP
0x20020: 0xbf00 NOP
0x20022: 0xbf00 NOP
0x20024: 0xbf00 NOP
0x20026: 0xbf00 NOP
0x20028: 0xbf00 NOP
0x2002a: 0xbf00 NOP
0x2002c: 0xbf00 NOP
0x2002e: 0xbf00 NOP
0x20030: 0xbf00 NOP
0x20032: 0xbf00 NOP
0x20034: 0xbf00 NOP
0x20036: 0xbf00 NOP
0x20038: 0xbf00 NOP
0x2003a: 0xbf00 NOP
0x2003c: 0xbf00 NOP
0x2003e: 0xbf00 NOP
0x20040: 0xbf00 NOP
0x20042: 0xbf00 NOP
0x20044: 0xbf00 NOP
0x20046: 0xbf00 NOP
0x20048: 0xbf00 NOP
0x2004a: 0xbf00 NOP
0x2004c: 0xbf00 NOP
0x2004e: 0xbf00 NOP
0x20050: 0xbf00 NOP
0x20052: 0xbf00 NOP
0x20054: 0xbf00 NOP
0x20056: 0xbf00 NOP
0x20058: 0x1e40 SUBS R0, R0, #1
0x2005a: 0xd1c3 BNE.N 0x1ffe4
__DMB();
0x2005c: 0xf3bf 0x8f5f DMB
The assembler generated by IAR 8.10 is :
0x22110: 0x4a3a LDR.N R2, [PC, #0xe8] ; 0xf42400 (16000000)
0x22112: 0x6001 STR R1, [R0]
0x22114: 0x4838 LDR.N R0, [PC, #0xe0] ; SystemCoreClock
0x22116: 0x6801 LDR R1, [R0]
0x22118: 0xbf00 NOP
0x2211a: 0xbf00 NOP
0x2211c: 0xbf00 NOP
0x2211e: 0xbf00 NOP
0x22120: 0xbf00 NOP
0x22122: 0xbf00 NOP
0x22124: 0xbf00 NOP
0x22126: 0xbf00 NOP
0x22128: 0x4291 CMP R1, R2
0x2212a: 0xd02f BEQ.N 0x2218c
0x2212c: 0xbf00 NOP
0x2212e: 0xbf00 NOP
0x22130: 0xbf00 NOP
0x22132: 0xbf00 NOP
0x22134: 0xbf00 NOP
0x22136: 0xbf00 NOP
0x22138: 0xbf00 NOP
0x2213a: 0xbf00 NOP
0x2213c: 0xbf00 NOP
0x2213e: 0xbf00 NOP
0x22140: 0xbf00 NOP
0x22142: 0xbf00 NOP
0x22144: 0xbf00 NOP
0x22146: 0xbf00 NOP
0x22148: 0xbf00 NOP
0x2214a: 0xbf00 NOP
0x2214c: 0xbf00 NOP
0x2214e: 0xbf00 NOP
0x22150: 0xbf00 NOP
0x22152: 0xbf00 NOP
0x22154: 0xbf00 NOP
0x22156: 0xbf00 NOP
0x22158: 0xbf00 NOP
0x2215a: 0xbf00 NOP
0x2215c: 0xbf00 NOP
0x2215e: 0xbf00 NOP
0x22160: 0xbf00 NOP
0x22162: 0xbf00 NOP
0x22164: 0xbf00 NOP
0x22166: 0xbf00 NOP
0x22168: 0xbf00 NOP
0x2216a: 0xbf00 NOP
0x2216c: 0xbf00 NOP
0x2216e: 0xbf00 NOP
0x22170: 0xbf00 NOP
0x22172: 0xbf00 NOP
0x22174: 0xbf00 NOP
0x22176: 0xbf00 NOP
0x22178: 0xbf00 NOP
0x2217a: 0xbf00 NOP
0x2217c: 0xbf00 NOP
0x2217e: 0xbf00 NOP
0x22180: 0xbf00 NOP
0x22182: 0xbf00 NOP
0x22184: 0xbf00 NOP
0x22186: 0xbf00 NOP
0x22188: 0xbf00 NOP
0x2218a: 0xbf00 NOP
0x2218c: 0x1e40 SUBS R0, R0, #1
0x2218e: 0xd1c3 BNE.N 0x22118
__DMB();
0x22190: 0xf3bf 0x8f5f DMB
The R0 register seems not to be initialized with IAR 8.10 so the program does not exit the loop. We can see in the code generated by IAR 7.60 that R0 is initialized with 47 (the Value we give to parameter "number_of_us" for this call). In IAR 8.10 R0 seems not to be initialized. This could have been made before function call due to compiler optimizations but it seems not to be the case (we have checked on debugger R0 register value). Can you help us?
