Hi, Can I use TI (cheap module 2451) as experimental blinky with central NRF52832.Don't need send button command , only UUID (TI:FFE0) check.It is possible?
Thanks
Thanks
Shouldn't you ask some1 from TI about that? If it properly works as peripheral BLE device, you should be able to use nrf52832 as central and communicate with it...
Or is the question about how to use the nRF52832 as a Central?
BLE central : NRF52832 (ble_app_multilink_central )
BLE peripherial : NRF51822 experimental_ble_app_blinky
When 51822(peripherial) powered on, central (52832) LED2 is ON,thats work fine.
I want change 51822 with CC2451.When powered TI module I want to light LED2 on 52832.
Central (nrf52832) check UUID , if correct LED2 is On.
And what is the problem?
How do i do it?
While change
LBS_UUID_BASE {0x23, 0xD1, 0xBC, 0xEA, 0x5F, 0x78, 0x23, 0x15,
0xDE, 0xEF, 0x12, 0x12, 0x00, 0x00, 0x00, 0x00}
to 0xE0, 0xFF not workind.
I need to set something else?
