I am currently working on a project involving the nRF52DK to be a central device.
The peripheral device is based on the Nordic Uart service with minor changes: UUID, access properties...
On the central side, I use ble_nus_c as an example but get an error which I can solve currently.
I am able to connect but not able to finish a GATT database discovery. The NUS service is found but not the characteristics. In ble_db_discovery.c, sd_ble_gattc_characteristics_discover return value 0x11. I guess that the input parameters are wrong but why, the handles are calculated by this module when the service is discovered?
I use the ble_nus_c service module only with a modified base UUID up to now.
Anyone could help? If so, what kind of information would you need? What should I look at with the debugger?
Thanks in advance for your help.
