Hi, We're using a 51422 with s130 to perform OTA DFU.
Both bases for bootloader and central are from sdk 12.2.
We have already implemented the older DFU (non-secure) for nRF51, which was a 128bit UUID, and it is working fine.
We started implementing the nRF52 DFU (16bit - 0xFE59). The initial conenction is successful, but when reaching the on_db_disc_evt, we get 2 characteristics that have 0 in both UUID and type.
Is this correct? If so, how do you distinguish between the characteristics and assign them?
This is the code for registering the service:
uint32_t ble_sdfu_c_init(ble_sdfu_c_t * p_ble_sdfu_c, ble_sdfu_c_init_t * p_ble_sdfu_c_init)
VERIFY_PARAM_NOT_NULL(p_ble_sdfu_c);
VERIFY_PARAM_NOT_NULL(p_ble_sdfu_c_init);
ble_uuid_t sdfu_uuid = {
.type = BLE_UUID_TYPE_BLE,
.uuid = BLE_UUID_SDFU_SERVICE, // 0xFE59
p_ble_sdfu_c->evt_handler = p_ble_sdfu_c_init->evt_handler;
p_ble_sdfu_c->conn_handle = BLE_CONN_HANDLE_INVALID;
p_ble_sdfu_c->handles.sdfu_control_point_handle = BLE_GATT_HANDLE_INVALID;
p_ble_sdfu_c->handles.sdfu_packet_handle = BLE_GATT_HANDLE_INVALID;
return ble_db_discovery_evt_register(&sdfu_uuid);
And this is the callback for the service discovery:
void ble_sdfu_c_on_db_disc_evt(ble_sdfu_c_t * p_ble_sdfu_c, ble_db_discovery_evt_t * p_evt)
ble_sdfu_c_evt_t sdfu_c_evt;
memset(&sdfu_c_evt,0,sizeof(ble_sdfu_c_evt_t));
ble_gatt_db_char_t * p_chars = p_evt->params.discovered_db.charateristics;
// Check if the DFU was discovered.
if (p_evt->evt_type == BLE_DB_DISCOVERY_COMPLETE &&
p_evt->params.discovered_db.srv_uuid.uuid == BLE_UUID_SDFU_SERVICE &&
p_evt->params.discovered_db.srv_uuid.type == BLE_UUID_TYPE_BLE) //p_ble_sdfu_c->uuid_type)
for (uint32_t i = 0; i < p_evt->params.discovered_db.char_count; i++)
switch (p_chars[i].characteristic.uuid.uuid) // <= THIS IS ALWAYS 0
case BLE_UUID_SDFU_CONTROL_POINT_CHARACTERISTIC:
sdfu_c_evt.handles.sdfu_control_point_handle = p_chars[i].characteristic.handle_value;
sdfu_c_evt.handles.sdfu_control_point_cccd_handle = p_chars[i].cccd_handle;
case BLE_UUID_SDFU_PACKET_CHARACTERISTIC:
sdfu_c_evt.handles.sdfu_packet_handle = p_chars[i].characteristic.handle_value;
if (p_ble_sdfu_c->evt_handler != NULL)
sdfu_c_evt.conn_handle = p_evt->conn_handle;
sdfu_c_evt.evt_type = SDFU_C_EVT_DISCOVERY_COMPLETE;
p_ble_sdfu_c->evt_handler(p_ble_sdfu_c, &sdfu_c_evt);
