How is BLE_CONN_HANDLE_INVALID changed in multiple services
I modified the ble_sdk_app_proximity example. I added x3 services, based on the BLE Characteristics, a beginner's tutorial, and it seems to be working fine. (nrf5-ble-tutorial-characteristic-CompletedCode ported for SDK 13.zip)
The first service, our_service.c from the turorial, works ok. The characteristic gets updated. The additional two (2) services did not until.......
It seems BLE_CONN_HANDLE_INVALID does not get changed to "VALID" or whatever.
So my service 2 and 3 does not update the characteristic.
When I comment out //p_our_service->conn_handle = BLE_CONN_HANDLE_INVALID; both the characteristics of the two additional services are updated.
So it seems the first service determines the connection state. Once it is connected, conn_handle ... stays .... BLE_CONN_HANDLE_INVALID for the other services?
How / where can I change BLE_CONN_HANDLE_INVALID to be "VALID"? (BLE_CONN_HANDLE_ALL)???
Any help appreciated
    As I think you have seen, the connection handle is set to whatever value the Softdevice decides in the function ble_our_service_on_ble_evt() at line 66, in our_service.c. Furthermore, ble_our_service_on_ble_evt() is called from the function ble_evt_dispatch() at line 551 in main.c. You should make similar functions and function calls for your new services.
    This doesn't make sense to me. At what line do you comment out this? Line 69 in our_service.c? Are you using the same ble_os_t type variable for all of your services? The one called m_our_service in main.c in the tutorial? If so you should probably make one such variable for each of your services.
  • Martin, I comment it out in the two new xxx_service.c files // OUR_JOB: Step 3.B, Set our service connection handle to default value. I.e. an invalid handle since we are not yet in a connection. //p_ppp_service->conn_handle = BLE_CONN_HANDLE_INVALID;
    NOTE: In either or both, of the new xxx_service.c files, if that line is Uncommented, the service does not get updated. I can still manually read or write to the value, but the auto update does not work, until I comment out //p_xxx_service->conn_handle = BLE_CONN_HANDLE_INVALID;
    I duplicate your our_service.c file, renamed all functions and variables to xxx_service, si I have // ALREADY_DONE_FOR_YOU: Declaration of a function that will take care of some housekeeping of ble connections related to our service and characteristic void ble_ppp_service_on_ble_evt(ble_ps_t * p_ppp_service, ble_evt_t * p_ble_evt)
  • Martin, FIXED the problem Your mentioning of ".. called from the function ble_evt_dispatch() .." made me re-check, and I had the calls for the two new services commented out. (Left over from testing). in ble_evt_dispatch(ble_evt_t * p_ble_evt)
    So I uncommented the 2 new services, and it worked!! Thanks (I also removed the comment for //p_sr2_service->conn_handle = BLE_CONN_HANDLE_INVALID; and //p_sr3_service->conn_handle = BLE_CONN_HANDLE_INVALID;
    // OUR_JOB: Step 3.C, Call ble_our_service_on_ble_evt() to do housekeeping of ble connections related to our service and characteristic
    ble_our_service_on_ble_evt(&m_our_service, p_ble_evt);
    ble_sr2_service_on_ble_evt(&m_sr2_service, p_ble_evt);
    ble_sr3_service_on_ble_evt(&m_sr3_service, p_ble_evt);
  • So the problem is solved then?
  • Yes, Thanks. I just wanted to show the fix, incase someone else runs into the same. Sorry, I should have closed this.
