OpenOCD and the NRF not flashing complete HEX file
I'm trying to flash a nRF518122 with a St-Link V2 programmer via Open OCD. The process seems to goes smooth, but comparing the number of written bytes to the actual HEX size are not the same (about a third) and (of course) the nRF51 does nothing.
This is the open OCD config I'm using (supplied by the hardware guy, I'm not sure why setting WORKAREASIZE to zero, but without it it doesn't work).
source [find interface/stlink-v2.cfg]
set WORKAREASIZE 0x0
transport select "hla_swd"
source [find target/nrf51.cfg]
reset_config srst_only srst_nogate
then I type openocd -f file_above.cfg:
Open On-Chip Debugger 0.9.0 (2015-09-02-10:42)
Licensed under GNU GPL v2
For bug reports, read
	openocd.org/.../bugs.html
Info : The selected transport took over low-level target control. The results might differ compared to plain JTAG/SWD
adapter speed: 1000 kHz
srst_only separate srst_nogate srst_open_drain connect_deassert_srst
Info : Unable to match requested speed 1000 kHz, using 950 kHz
Info : clock speed 950 kHz
Info : STLINK v2 JTAG v23 API v2 SWIM v4 VID 0x0483 PID 0x3748
Info : using stlink api v2
Info : Target voltage: 3.249474
Info : nrf51.cpu: hardware has 4 breakpoints, 2 watchpoints
then telnet 127.0.0.1 4444:
Trying 127.0.0.1...
Connected to 127.0.0.1.
Escape character is '^]'.
> halt
target state: halted
target halted due to debug-request, current mode: Handler HardFault
xPSR: 0x01000003 pc: 0x0000a152 msp: 0x20003964
> nrf51 mass_erase
Unknown device (HWID 0x0000008f)
> flash write_image <full_path>/zephyr.hex 0
Padding image section 0 with 2 bytes
not enough working area available(requested 32)
no working area available, falling back to slow memory writes
wrote 47164 bytes from file <full path>/zephyr.hex in 7.741681s (5.949 KiB/s)
The hex is compiled with gccarm from Zephyr-rtos_hci_uart (and changed the pins on nRF51_pca10028.defconfig to be the 1 and 2 as per WT51822 datasheet)
The same hex on pins 1-2 and the original hex compiled with the default pins 9-11 flashed via nRF Go to the nRF51-DK works without issues (via cables on pins 1-2 and the USB-UART connection respectively)
calling > flash banks gives me
#0 : nrf51.flash (nrf51) at 0x00000000, size 0x00040000, buswidth 1, chipwidth 1
#1 : nrf51.uicr (nrf51) at 0x10001000, size 0x00000100, buswidth 1, chipwidth 1
and I was wondering if Softdevice that came pre-programmed from the hardware guy is there and "taking space" and I have to re-order those banks, but I'm afraid of messing the bootloader, so I rather ask here before.
Any help appreciated.
update: I recompiled OpenOCD to add HWID 0x0000008f and now nrf51 mass_erase replies with nRF51822-QFAA(build code: H1) 256kB Flash but flashing still only goes up to 47164 bytes.
