How do I deny a connection if the connection is unencrypted? I'm currently trying to do it with the peer_manager using
case PM_EVT_CONN_SEC_FAILED:
/** In some cases, when securing fails, it can be restarted directly. Sometimes it can
* be restarted, but only after changing some Security Parameters. Sometimes, it cannot
* be restarted until the link is disconnected and reconnected. Sometimes it is
* impossible, to secure the link, or the peer device does not support it. How to
* handle this error is highly application dependent. */
switch (p_evt->params.conn_sec_failed.error)
case PM_CONN_SEC_ERROR_PIN_OR_KEY_MISSING:
/* Completely deny the connection */
err_code = sd_ble_gap_disconnect(p_evt->conn_handle,
BLE_HCI_LOCAL_HOST_TERMINATED_CONNECTION);
}break;//PM_EVT_CONN_SEC_FAILED
case PM_EVT_CONN_SEC_CONFIG_REQ:
pm_conn_sec_config_t conn_sec_config = {.allow_repairing = false};
pm_conn_sec_config_reply(p_evt->conn_handle, &conn_sec_config);
}break;//PM_EVT_CONN_SEC_CONFIG_REQ
But it doesn't seem to be denying instantly denying the connection. What is the best way to prevent unencrypted connections from accessing the device? I want to be able to do this with either pairing or bonding. It is my understanding that characteristic encryption requires bonding.
