I have a device with nRF52832 and firmware is composed of Bootloader (BL), softdevice (SD) S132 v2.0.0, application and I am using SDK 11.0.
I have created different firmware updates (BL, SD, App, BL+SD, etc.) in ZIP format (using nrfutil v2.2.0) and when I try to perform a DFU over BLE, I always end up with DFU_BANK_0_REGION_START (Addr: 0x0001C000) with all its content reset to 0xFFFFFFFF.
I use the application setting provided by Nordic support for nRF52 and I merge it together with the other HEX included in the ZIP files:
:020000040007F3
:10F000000100000000000000FE000000FFFFFFFF05
:00000001FF
I have tried using the ZIP files provided in the SDK 11.0 in the example projects related to DFU usage, but even those fail. With the only difference that with those example ZIP files, actually the files get transferred (using Android app nRF Connect).
This is a sequence of events happening in my system when I try to perform a DFU (I have printed some log messages):
ble_evt_dispatch(): p_ble_evt->header.evt_id 16 -> BLE_GAP_EVT_CONNECTED
ble_evt_dispatch(): p_ble_evt->header.evt_id 18 -> BLE_GAP_EVT_CONN_PARAM_UPDATE
ble_evt_dispatch(): p_ble_evt->header.evt_id 80 -> BLE_GATTS_EVT_WRITE
ble_evt_dispatch(): p_ble_evt->header.evt_id 81 -> BLE_GATTS_EVT_RW_AUTHORIZE_REQUEST
bootloader_dfu_update_process() update_status = 4 -> DFU_BANK_0_ERASED
ble_evt_dispatch(): p_ble_evt->header.evt_id 1 -> BLE_EVT_TX_COMPLETE
bootloader_dfu_update_process() update_status = 6 -> DFU_RESET
bootloader_app_is_valid(): EMPTY_FLASH_MASK
Resetting
[After restarting]
bootloader_app_is_valid(): Application at DFU_BANK_0_REGION_START is not valid!
Do you have any suggestions on how to make it work. I am pretty sure it is just a matter of creating the proper ZIP file and/or incompatibility of SDK/DFU Manager/Android App.
Thank you for the support.
Marco
