Hello to everyone in this community,
I am new with NordicSemi chips and I have the Development kit 52832. I opened the example folder from the SDK 13, SPI slave and i saw some code using NRF_LOG_INFO in order to print something in one terminal, I think so, but when I flash the memory with the code with help of Eclipse and using the J-link flash tool. flash: $(OUTPUT_DIRECTORY)/nrf52832_xxaa.hex @echo Flashing: $(NRFJPROG_CMD) --program $(OUTPUT_DIRECTORY)/nrf52832_xxaa.hex -f nrf52 --sectorerase $(NRFJPROG_CMD) --reset -f nrf52
I open Tera Term with the following setup Baute rate: 115200 data: 8 bit Pariry: none Stop: 1 bit Flow control: none
Anything is printed out in the terminal screen. Then i read in order tread, that I need to change the code in the sdk_config.h.
#ifndef NRF_LOG_BACKEND_SERIAL_USES_UART #define NRF_LOG_BACKEND_SERIAL_USES_UART 1 #endif
After flashing again, Im still having the same problem.
Then I change to the J-link RTT viewer, obviolsy i change the UART to 0 again, then I open the J-link programm with RRT and nothing.
#ifndef NRF_LOG_BACKEND_SERIAL_USES_RTT #define NRF_LOG_BACKEND_SERIAL_USES_RTT 1 #endif
Someone can explain me how can I print out some string then?
David Caraveo
