DFU Update from SDK 12.2 to SDK 13.0
As Bootloader IROM starting address 0x78000 and size 0x6000 is same in SDK 13.0 and 12.2.0 expecting to update Device firmware (BL+SD+APP) from 12.2.0 to 13.0.0 SDK.But in my case DFU update (secure BL+SD+APP) or DFU Update (secure BL+SD) from 12.02 to 13.0 is failing even though private keys are same.`
Also tested DFU updates are working for without issues from 12.0.2 to 12.0.2 and 13.0 to 13.0 without any issues.
  • Hello, Able to update but need to
    1. Create DFU distribution package first without APP only BL+SD of SDK 13.0 with --sd-req =0x91 instead of 0x98 in nrfutil pkg generate options
    2. Update Device firmware from 12.2.0 with package generate in step 1
    3. Create a Distribution package containing App only now --sd-req =0x98 .
    4. Update Device firmware App with step 3 distribution package
    Note:- BL version with incremented and App version can same or incremented version as per nordic documentation
    Not sure why -sd-req should have same version which is on device expected it should be sd version in package someone from nordic can provide more information
  • @srikar: You should be able to specify more than one softdevice requirement uisng commas, i.e.
    --sd-req 0x98,0x91
    That way the image will be compatible with both the old and the new SoftDevice version.
