I use ble_app_hrs_s132 project for experiment on bonding function. The version of SDK is v12.2.0. It seems that this example has all the conditions the bonding function needs according to the document. Following is all the step:
1.initialization
peer_manager_init(erase_bonds)
ret_code_t err_code;
err_code = pm_init();
if (erase_bonds)
err_code = pm_peers_delete();
sec_param.bond = SEC_PARAM_BOND;
sec_param.mitm = SEC_PARAM_MITM;
sec_param.io_caps = SEC_PARAM_IO_CAPABILITIES;
sec_param.oob = SEC_PARAM_OOB;
sec_param.min_key_size = SEC_PARAM_MIN_KEY_SIZE;
sec_param.max_key_size = SEC_PARAM_MAX_KEY_SIZE;
sec_param.kdist_own.enc = 1;
sec_param.kdist_own.id = 1;
sec_param.kdist_peer.enc = 1;
sec_param.kdist_peer.id = 1;
err_code = fds_register(fds_evt_handler);
2.Event can be triggered when bonding from central device.
static void pm_evt_handler(pm_evt_t const * p_evt)
switch (p_evt->evt_id)
case PM_EVT_BONDED_PEER_CONNECTED:
NRF_LOG_INFO("Connected to a previously bonded device.\r\n");
} break;
case PM_EVT_CONN_SEC_SUCCEEDED:
NRF_LOG_INFO("Connection secured. Role: %d. conn_handle: %d, Procedure: %d\r\n",
ble_conn_state_role(p_evt->conn_handle),
p_evt->conn_handle,
p_evt->params.conn_sec_succeeded.procedure);
} break;
case PM_EVT_CONN_SEC_FAILED:
/* Often, when securing fails, it shouldn't be restarted, for security reasons.
* Other times, it can be restarted directly.
* Sometimes it can be restarted, but only after changing some Security Parameters.
* Sometimes, it cannot be restarted until the link is disconnected and reconnected.
* Sometimes it is impossible, to secure the link, or the peer device does not support it.
* How to handle this error is highly application dependent. */
} break;
case PM_EVT_CONN_SEC_CONFIG_REQ:
// Reject pairing request from an already bonded peer.
pm_conn_sec_config_t conn_sec_config = {.allow_repairing = false};
pm_conn_sec_config_reply(p_evt->conn_handle, &conn_sec_config);
} break;
case PM_EVT_STORAGE_FULL:
// Run garbage collection on the flash.
err_code = fds_gc();
if (err_code == FDS_ERR_BUSY || err_code == FDS_ERR_NO_SPACE_IN_QUEUES)
// Retry.
} break;
advertising_start();
} break;
case PM_EVT_LOCAL_DB_CACHE_APPLY_FAILED:
// The local database has likely changed, send service changed indications.
pm_local_database_has_changed();
} break;
case PM_EVT_PEER_DATA_UPDATE_FAILED:
// Assert.
APP_ERROR_CHECK(p_evt->params.peer_data_update_failed.error);
} break;
case PM_EVT_PEER_DELETE_FAILED:
// Assert.
APP_ERROR_CHECK(p_evt->params.peer_delete_failed.error);
} break;
case PM_EVT_PEERS_DELETE_FAILED:
// Assert.
APP_ERROR_CHECK(p_evt->params.peers_delete_failed_evt.error);
} break;
case PM_EVT_ERROR_UNEXPECTED:
// Assert.
APP_ERROR_CHECK(p_evt->params.error_unexpected.error);
} break;
case PM_EVT_CONN_SEC_START:
case PM_EVT_PEER_DATA_UPDATE_SUCCEEDED:
case PM_EVT_PEER_DELETE_SUCCEEDED:
case PM_EVT_LOCAL_DB_CACHE_APPLIED:
case PM_EVT_SERVICE_CHANGED_IND_SENT:
case PM_EVT_SERVICE_CHANGED_IND_CONFIRMED:
static void fds_evt_handler(fds_evt_t const * const p_evt)
if (p_evt->id == FDS_EVT_GC)
NRF_LOG_DEBUG("GC completed\n");
3.dispatch event
static void ble_evt_dispatch(ble_evt_t * p_ble_evt)
ble_conn_state_on_ble_evt(p_ble_evt);
pm_on_ble_evt(p_ble_evt);
ble_hrs_on_ble_evt(&m_hrs, p_ble_evt);
ble_bas_on_ble_evt(&m_bas, p_ble_evt);
ble_prs_on_ble_evt(&m_prs, p_ble_evt);
ble_conn_params_on_ble_evt(p_ble_evt);
bsp_btn_ble_on_ble_evt(p_ble_evt);
ble_advertising_on_ble_evt(p_ble_evt);
nrf_ble_gatt_on_ble_evt(&m_gatt, p_ble_evt);
All above are the example offers. Is there anything wrong with it? When I bond it from my central device and then disconnect it, I find that another BLE central device can also connect it. It shows that bonding failed. So I don't know what wrong with it.
I am looking forward to your replay. Thanks!
