Using existing examples in SDK13, I prepared ADC sampling app which works fine in ESB TX mode. Works well sending frames at 10ksps, and I can also put it to 'standby mode' by remote command from RX, when it wakes up on RTC every 2s, 'feeds the dog', sends a dummy frame (so Tx is able to receive a command from Rx)
What I have to do, is to get Low Power consumption in 2 seconds idle period. What is the best way to reduce currentt and keep only RTC running?
I give it long SAADC timer value before trying to sleep or even disable it - no effect. there is NRF_TIMER_CC_CHANNEL used and PPI_channel: timer compare event triggering sample task - I didn't touch it.
There isn't any usual hardware defined, which might request HF clock running (eg.UART) I disable HFCLK: NRF_CLOCK->TASKS_HFCLKSTOP = 1; and reeanable it on RTC interrupt
-do I have to disable the radio with nrf_esb_disable() before sleep and re-eanable it after NRF_CLOCK->TASKS_HFCLKSTART = 1; on RTC interrupt?
I tried to put device to sleep with __WFE(); __SEV(); __WFE(); sequence I try to call nrf_pwr_mgmt_run(). No matter what I do, I always end up with 2mA current or slightly less with NRF_POWER->DCDCEN = 1
with applying: nrf_drv_saadc_uninit() fix suggested here the app draws 0.8mA but does not wake up on RTC.
Please provide me any suggestions. Thanks in advance! Tom
