This test program is modified from examples\pin_change_int\main.c, I add the instructions to put the cpu to sleep. And I add nrf_gpio_input_disconnect() for all the pins except BSP_BUTTON_0 and BSP_LED_0. Everything else remains as original example.
gpio_init();
while (true)
// Enter System ON sleep mode
__WFE();
__SEV();
__WFE();
By using a DMM to measure the current, I get about 8 uA (I use external power, not USB). When I use the Nordic Power Profiler Kit, I also get similar average current. I notice the graph shows a peak about every 5.2 msec.
Is there some timer left running by default? Does the GPIOTE require some clock running during sleep?
I saw this thread, devzone.nordicsemi.com/.../ I ran the "System On" example, I get about 12 uA during sleep, but 2.6 uA was expected.
