Hi
Does the CryptoCell in the nRF52840 support secp256k1? In this documentation it says at one point Koblitz curves using fixed parameters, up to 256 bits, are supported, but then in the table below I don't see the curve listed.
Thanks
Hi
Thanks
Yes, this should be supported. Using nrf_crypto library you can use NRF_CRYPTO_CURVE_SECP256K1
from nrf_ecc_curve_type_t
to use Koblitz 256-bit curves. If using the CC310 API directly, you should use CRYS_ECPKI_DomainID_secp256k1
Jørgen
