Hi, Following the docs I think I am able to write to flash but it will not read anything .
This is how I set it up, write and read :
static void sys_evt_dispatch(uint32_t sys_evt)
fs_sys_event_handler(sys_evt);
ble_advertising_on_sys_evt(sys_evt);
static void fds_evt_handler(fds_evt_t const * const p_fds_evt)
switch (p_fds_evt->id)
case FDS_EVT_INIT:
if (p_fds_evt->result != FDS_SUCCESS)
NRF_LOG_INFO("failed initializing\r\n");
case FDS_EVT_WRITE:
if (p_fds_evt->result == FDS_SUCCESS)
write_flag=1;
NRF_LOG_INFO("finish write\r\n");
void initStorage()
ret_code_t ret = fds_register(fds_evt_handler);
if (ret != FDS_SUCCESS)
NRF_LOG_INFO("FAILED TO INIT STORAGE\r\n");
ret = fds_init();
NRF_LOG_INFO("ERROR INIT\r\n");
NRF_LOG_INFO("INIT IT \r\n");
void write()
#define FILE_ID 0x1111
#define REC_KEY 0x2222
static uint32_t const m_deadbeef = 0xDEADBEEF;
fds_record_t record;
fds_record_desc_t record_desc;
fds_record_chunk_t record_chunk;
// Set up data.
record_chunk.p_data = &m_deadbeef;
record_chunk.length_words = 1;
// Set up record.
record.file_id = FILE_ID;
record.key = REC_KEY;
record.data.p_chunks = &record_chunk;
record.data.num_chunks = 1;
ret_code_t ret = fds_record_write(&record_desc, &record);
NRF_LOG_INFO("FAILED TO SAVE\r\n");
NRF_LOG_INFO("Writing Record ID = %d \r\n",record_desc.record_id);
void read ()
NRF_LOG_INFO("START READING\r\n");
fds_flash_record_t flash_record;
fds_find_token_t ftok={0};
// Loop until all records with the given key and file ID have been found.
while (fds_record_find(FILE_ID, REC_KEY, &record_desc, &ftok) == FDS_SUCCESS)
NRF_LOG_INFO("FOUND SOMETHING\r\n");
if (fds_record_open(&record_desc, &flash_record) != FDS_SUCCESS)
NRF_LOG_INFO("ERROR OPEN\r\n");
// Access the record through the flash_record structure.
NRF_LOG_INFO("Found Record ID = %d\r\n",record_desc.record_id);
//NRF_LOG_INFO("Found data = %s\r\n",flash_record.p_data);
// Close the record when done.
if (fds_record_close(&record_desc) != FDS_SUCCESS)
NRF_LOG_INFO("ERROR CLOSE\r\n");
I can see that there are no errors so it means I am able to init and write with :
initStorage();
nrf_delay_ms(1000);
write();
nrf_delay_ms(1000);
read ();
You can see on the log that the FDS_EVT_WRITE will not be called but I do get a record write ID ! The log :
:INFO:PROGRAM STARTED
:INFO:INIT IT
:INFO:Writing Record ID = 1
:INFO:START READING
