I was able to use the fds with the help of good people here , I am trying now to save a word into memory.
As I see in the docs, the only way to save data is by uint32_t chunks .
So I guess I am doing it wrong but I am trying this without success :
to save with this :
char data[]="lola";
uint32_t save;
memcpy(&save, data, 4);
#define FILE_ID 0x1111
#define REC_KEY 0x2222
fds_record_t record;
fds_record_desc_t record_desc;
fds_record_chunk_t record_chunk;
// Set up data.
record_chunk.p_data = &save;
record_chunk.length_words = 1;
// Set up record.
record.file_id = FILE_ID;
record.key = REC_KEY;
record.data.p_chunks = &record_chunk;
record.data.num_chunks = 1;
Then to read with :
... //some code that works , then
data = (uint32_t *) flash_record.p_data;
for (uint8_t i=0;i<flash_record.p_header->tl.length_words;i++)
char bytes[6];
char n = data[i];
bytes[0] = (n >> 24) & 0xFF;
bytes[1] = (n >> 16) & 0xFF;
bytes[2] = (n >> 8) & 0xFF;
bytes[3] = n & 0xFF;
for (int k=0;k<4;k++)
NRF_LOG_INFO("message is: %c ",bytes[k]);
//NRF_LOG_INFO("record ID: %d and data: %x ",record_desc.record_id,data[i]);
Which will print record 1 and data
- means empty data
- Is this the way to save a word ?
- what about saving multiple words like this ? is it a overhead ?
Thanks !
