Hi, I used the hrs example found some problems, the problem is described as follows: I use the Android phone pairing binding device, when I cancel the pairing on the phone, click again when the phone found that the phone can not match the device,
What did you mean by "cancel the pairing on the phone" Did you mean you remove bonding on the phone ?
In that case you need to remove bonding on the device also. Press and hold button 1 when reset the device will delete bond information.
