I'm migrating from SDK11 to SDK13. My custom service is based off Heart Rate Service, so I started from the new SDK13 example of HRS, and updated all the initialization code following the new example.
Changed: ble_cg.common_cg.vs_uuid__cfg.vs_uuid_count = 2; and adjusted the linker script according to the forum post answer about this.
The issue that comes up appears to occur in the on_connect function within the service. If i comment it out, I can connect, discover services and receive write events. With it implemented, the firmware hangs right after the connection event.
The on_connect function is literally just assigning the conn_handle, is there anything going on behind the scenes in the softdevice at this point?
static void on_connect(ble_cgm_t * p_cgm, ble_evt_t * p_ble_evt)
p_cgm->conn_handle = p_ble_evt->evt.evt.gap_evt.conn_handle;
The value of conn_handle is 0. I've tried manually setting p_cgm->conn_handle to 0 at this point as well, and the same thing occurs. Should conn_handle not be 0?
I have tried both with and without the new gatt_evt, just in case that was the issue, but doesn't appear to be it.
Thanks
EDIT: additional code Function where on_connect is called
void ble_cgm_on_ble_evt(ble_cgm_t * p_cgm, ble_evt_t * p_ble_evt)
case BLE_GAP_EVT_CONNECTED:
on_connect(p_cgm, p_ble_evt);
on_disconnect(p_cgm, p_ble_evt);
case BLE_GATTS_EVT_WRITE:
on_write(p_cgm, p_ble_evt);
// No implementation needed.
the ble_cgm_on_ble_evt handler is called from a higher level handler: cgm_on_ble_evt (shown below), which is called directly from ble_evt_dispatch
void cgm_on_ble_evt(ble_evt_t * p_ble_evt)
case BLE_GATTS_EVT_HVN_TX_COMPLETE: //depreciated: BLE_EVT_TX_COMPLETE:
if (sending)
if(data_ready)
continueDataSend();
if (backwards && (sendingStart-sendingLength) > sendingEnd)
sending = true;
dataSyncSendBackward(sendingEnd, (sendingStart-sendingLength));
if (!backwards && (sendingStart+sendingLength) < sendingEnd)
sending = true;
dataSyncSendForward((sendingStart+sendingLength), sendingEnd);
ble_cgm_on_ble_evt(&m_cgm, p_ble_evt);
This handler (cgm_on_ble_evt) is at the level where m_cgm is defined
ble_cgm_t m_cgm; /**< Structure used to identify the CGM service. */
And the ble_cgm_t structure looks like this.
/**@brief Service structure. This contains various status information for the service. */
struct ble_cgm_s
ble_cgm_evt_handler_t evt_handler; /**< Event handler to be called for handling events in the Service. */
uint16_t service_handle; /**< Handle of the CGM Service (as provided by the BLE stack). */
ble_gatts_char_handles_t lsm_handles; /**< Handles related to the Live Stream characteristic. */
ble_gatts_char_handles_t data_handles; /**< Handles related to the Data Sync characteristic. */
ble_gatts_char_handles_t cmd_handles; /**< Handles related to the Command characteristic. */
ble_gatts_char_handles_t stat_handles; /**< Handles related to the Status characteristic. */
uint16_t conn_handle; /**< Handle of the current connection (as provided by the BLE stack) */
uint8_t uuid_type; /**< UUID type for the CGM Service. */
ble_cgm_cmd_write_handler_t cmd_write_handler; /**< Event handler to be called when the CMD Characteristic is written. */
//uint8_t max_cgm_len; /**< Current maximum CGM Packet length, adjusted according to the current ATT MTU. */
Does ble_cg.common_cg.vs_uuid__cfg.vs_uuid_count need to account for each CHAR UUID?
