wake up the CPU
hello,
could anyone tell me how to wake up the CPU after a sd_power_system_off () ?
Thanks.
  • Yes, one way is to configure a GPIO pin for wakeup. This is demonstrated in nordic sample applications. They generally go to system off after the long advertising timeout.
    Reset sources like power-on reset will also bring a device out of system off.
    After learning more about your application, I'd like to recommend this approach to you:
    Register your switch/button with the app_button module and when you detect a low to high transition, go into system_off. Before that, run this code: // Configure switch with sense level low as wakeup source. nrf_gpio_cfg_sense_input(YOUR_PIN_NUMBER, NRF_GPIO_PIN_NOPULL, NRF_GPIO_PIN_SENSE_LOW);
    When the switch level goes back to low, you leave system_off and begin executing code @ the top of main(); Let me know if you have any other concerns.
  • I'm trying to Switch the system off or one with a switch pin : Switch-off == 1 {system off} Switch-off == 0 {system on}
    which one of the referred to wake up the system do recommand ?
    thanks
  • Howdy: I've updated my question. Alternatively you can power down the whole system with your switch but I can see certain circumstances where you may not want to do that...
