Hello I have this error:
Checking installed packages
pyside: 1.2.4
pyqtgraph: 0.10.0
numpy: 1.12.1
pynrfjprog: 9.0.0
Warning: The software is tested with PyQtGraph 0.9.10, and may not work with your version (0.10.0)
Warning: The software is tested with np 1.9.2, and may not work with your version (1.12.1)
Power Profiler Kit started, initializing...
Unable to connect to the PPK, check debugger connection and make sure pynrfjprog is up to date.
I did try to run on other PC and it works. So I'm sure HW switches and FW and everything shall be OK.
I read other threads other threads
And I have everything:
Python 2.7.13 (v2.7.13:a06454b1afa1, Dec 17 2016, 20:42:59) [MSC v.1500 32 bit (Intel)] on win32
I did install MSVC 9.0 (2008) redistributable (vcredist_x86.exe)
I did run python_packages.bat
I even try to reinstall python 2.7 freshly...
Any other hint???
Also can be the PPK code improved in error reporting? If there is more details what is wrong we could solve it faster...
