Error Code 0x3401
Hi, I'm calling sd_ble_gatts_hvx and every once in a while I get an error code of 0x3401. I went through the SDK documentation but I could not find what that error code is. Have you seen this error code before? thank you, akbar
  • I'm assuming you are using S110 v7.0.0
    0x3XXX = Stack error
    0x34XX = GATTS error
    0x3401 = BLE_ERROR_GATTS_SYS_ATTR_MISSING
    This error comes when the stack does not know the state of the CCCD, and whether notifications/indications are enabled for that specific characteristic. When connecting to a brand new device, the attribute states should be set with NULL as a param, resetting all the CCCD states to disallowing HVX. For a bonded device, however, the previous states need to be restored. This handling is left to the application in the current SoftDevices by using sd_ble_gatts_sys_attr_get() upon disconnection and and _set() on reconnection to the same device.
    The handling of system attributes (and more) should be handled in the Device Manager SDK module.
  • Hi Ulrich, thank you very much for your answer. I am indeed using S110 v7.0.0!
    I'm using softdevice 7.0.0 and last sdk,
    The same error occur when i want to send notification with notifications not enables despite catching NRF_ERROR_INVALID_STATE :
    err_code = sd_ble_gatts_hvx(p_bts->conn_handle, &params);
    		if (err_code != NRF_SUCCESS &&
    			err_code != BLE_ERROR_INVALID_CONN_HANDLE &&
    			err_code != NRF_ERROR_INVALID_STATE)
    I'm not using bond manager and CCCD attributes are initialized after BLE_GATTS_EVT_SYS_ATTR_MISSING event :
            err_code = sd_ble_gatts_sys_attr_set(m_conn_handle, NULL, 0);
    How i can avoid this error ?
    Thomas
  • You will only get the SYS_ATTR_MISSING event if a peer GATT client tries to read a CCCD state, so this might not have happened yet. You should instead set system attributes on CONNECTED. If you try to indicate/notify a characteristic that the SoftDevice does not know the state of, you will get this return code as specified in the documentation: devzone.nordicsemi.com/.../a00922.html
