S110 v7 HVX notification bug
I am not sure, but i think we found bug or some interesting feature in sending notification values.
Here is the code i used:
uint32_t ble_meas_on_ext_adc_change(ble_meas_t * p_meas, uint32_t adcread){
uint32_t err_code = NRF_SUCCESS;
static uint8_t _sampling_counter;
if(adcread != p_meas->ext_adc_last_state)
    _sampling_counter++;
    uint16_t len = 5;
    uint8_t buffer[5];
    memcpy(buffer, (void *)&adcread, sizeof(uint32_t));
    buffer[4] = _sampling_counter;
    p_meas->ext_adc_last_state = adcread;
    err_code = sd_ble_gatts_value_set(p_meas->ext_adc_char_handles.value_handle,
                                      0,
                                      &len,
                                      buffer);
    if (err_code != NRF_SUCCESS)
        return err_code;
    if((p_meas->conn_handle != BLE_CONN_HANDLE_INVALID) && p_meas->ext_adc_is_notification_enabled)
        ble_gatts_hvx_params_t params;
        memset(&params, 0, sizeof(params));
        len = sizeof(uint16_t);
        params.handle   = p_meas->ext_adc_char_handles.value_handle;
        params.type     = BLE_GATT_HVX_NOTIFICATION;
        params.p_len    = &len;
        params.p_data   = (uint8_t *)&adcread;
        return sd_ble_gatts_hvx(p_meas->conn_handle, &params);
return err_code;
On the beginning i check if last reading from ADC is different comparing to new value (adcread). Next, I copy the value to 5byte buffer and add _sampling_counter. I succesfully set whole buffer as characteristic value. To this point, everything is clear.
And now comes black magic - I want to send notification with this new value, and i set p_len as 2 bytes (which is so wrong - should be 5 bytes!) and p_data as (uint8_t *)&adcread (adcread still contains only 4 bytes, which is my fault again - it should be buffer instead).
So if everything would work correctly, i assume that HVX notification should only contain 2 first bytes of adcread, but when i receive it on my central device, i got all 5 bytes from buffer[] which i actually wanted to receive. What is going on here? Does hvx notification ignore p_data and sends data stored in characteristic value?
