nRF Connect, Ubuntu Gnome 17.04, blank window
Hello everyone,
I'm usually on the cutting edge with Ubuntu Linux. I upgrade my development box frequently, because I like the precompiled binaries in the Ubuntu repository. I prefer to use my time building nRF52 apps from source, rather than building Linux apps from source.
I just upgraded to Ubuntu Gnome 17.04. I also have nRF Connect v 1.1.1. I have a PCA10040 board connected to a USB port, to use as a BLE receiver.
I had everything working in 16.04, save for a mysterious, but apparently harmless, JavaScript error message which occurred when I closed nRF Connect (click here if you're interested).
On 17.04, nRF Connect starts up correctly. The Select serial port pull down menu shows my PCA10040 board attached to /dev/tty/ACM0. However, when I select that board, the whole nRF Connect window goes... blank.
Please advise, thanks.
  • Can you open the console log window by clicking Shift + Ctrl + i in nRF Connect, and see if there are any errors reported?
  • Thanks for your reply, Jørgen. I didn't know about the console log window. It does not appear that I can post a screen shot, so I will have to type what I saw, and it may run longer than one post.
    Item 1 in the console log:
    /home/john/bin/nrf-connect-linux-x64/resources/app/node_modules/nrfconnect-appmodule-ble/node_modules/react/lib/ReactDOM.js:75
    Download the React DevTools and use an HTTP server (instead of a file: URL) for a better development experience: https://fb.me/react-devtools
    Item 2:
    bundle.js:8483
    Database is not ready yet. Storing entries in queue for later storage in DB.
    (to be continued)
  • Item 3:
    /home/john/bin/nrf-connect-linux-x64/resources/app/node_modules/nrfconnect-appmodule-ble/node_modules/fbjs/lib/warning.js:36
    Warning: Using Maps as children is not yet fully supported. It is an experimental feature that might be removed. Convert it to a sequence / iterable of keyed ReactElements instead. Check the render method of DiscoveredDevices.
    Item 4:
    bundle.js:8483
    Finally, when I try to connect to my PCA10040 board with the console log open, I see a popup window that was not visible with the console log closed. It reads:
    DevTools was disconnected from the page. Once page is reloaded, DevTools will automatically reconnect.
    Hope that helps. Thank you!
  • One last thing. My development box is a dual-boot, Windows 10 and Ubuntu system. I just installed JLink and nRF Connect on Windows 10. It works without errors. The problem is software, not hardware. I can boot into Windows when I need to do BLE work for now, but in the long run I would also like nRF Connect working on top of Ubuntu Gnome 17.04. Thanks.
  • Could you try the following (if you have not allready):
    • Install Google Chrome and all dependecies.
    • Install latest JLink driver.
    • Erase the board using nrfjprog eraseall command.
    • Upgrade JLink Interface FW to latest version.
    • Program the connectivity HEX file directly using nrfjprog. The file (for PCA10040) can be found in nrf-connect-linux-x64/resources/app/node_modules/nrfconnect-appmodule-ble/node_modules/pc-ble-driver-js/pc-ble-driver/hex/sd_api_v3
