nRFgo studio can not find the chip on nRF6310 board!!!
Hi everyone,
Just recently I've got two nRF6310 EVB boards with a nRF51822! When I connect board via USB and open the nRFgo Studio, it can recognize the board as nRF ISP motherboard connector! I want to test the joystick, LCD board by the programming precompiled relative hex code! When I click on the motherboard it shows a page which seems I'm able to program it. I choose a the mentioned hex file to program in the motherboard! Also an hex file which all are zero (I generated it by edit NV data button), the selected device is nRF24LE1! When I try to program the says "could not detect the chip"! I'm quite confused because this board does have just AT90USB1287 and don't think it is possible to program it via USB! Be aware that I don't have Segger programmer! Do I need to have a segger programmer also? If I need Segger programmer what model of it must be used?! How about JTAG programmer? May I use a JTAG programmer also? Please somebody tell me how is the whole workflow and initialization for the nRF6310 motherboard and the nRF51822!
With same story when I try to use the keil-uV after successful compiling of joystick-LCD project, when I try to load the program it says Flash programming failed!
Please kindly let me know what's wrong with this procedure! Would you please kindly introduce me a document which is useful to know whole procedure from A-Z to use all motherboard and Module options?! Since I have added my product in myPage of Nordic I just got few documents which I think they are not that useful specially to solve my current problem!
Thanks~
