I’m working on a device that requires to enable the softdevice when connecting with a smartphone via Bluetooth and disable it when acquiring data from an analog source.
In order to do this I have created a simple state-machine and using the nRF52832 with sdk version 11.
I need to have a time-base low powered reference for dealing with measure interrupt timing and softdevice activity (no hard real-time constraint needed).
I use HFCLK for better accuracy of ADC measuring (simple-task mode).
I found that RTC0 is a dedicated peripheral for the softdevice and wondered if it can also be used after disabling/enabling the softdevice.
Here is a simple diagram of the working principle of the state-machine:
Is there a functional discontinuity of RTC0 if application timer is used for the state machine timing and task synchronizing while disabling/enabling the softdevice?
Can I use RTC0 as state-machine time base?
I also found that RTC1 is proposed as application timer.
In that case, can it be synchronized with RTC0 of the softdevice and the ADC Measure?
Can you please give a code example for RTC peripheral synchronization?
Thank you,
Flinn
