How to disable buffer in Nordic Uart Service?
I'm trying to replace a RS232 cable with a BLE bridge with the Nordic Uart Service.
One nRF52832 configured as central (app_uart_example_central) and an other one as peripheral. The connection is working well with putty or the nRF connect app on the phone. But there is a 60 character buffer and I can't find the code to change it.
Does someone know how to disable that buffer to send incoming data as it comes?
Details: Chip: nRF52832 IDE: Keil5.23 Softdevice: s132
  • Hi Hermann
    I don't think removing the buffer is the best option, since having the buffer is a good way to ensure you can send larger chunks of data at once, but what you can do is to add some code to empty the buffer more aggressively.
    For instance you can set up an app_timer callback that checks the buffer every N milliseconds, and sends whatever is in the buffer as long as it is not empty. Then you know that your data will be sent on certain intervals, even if you haven't filled the buffer first.
    Best regards
    Torbjørn
  • Hi Torbjørn,
    thanks for your tip with the timer.
    I created a app_timer (single_shot) which is (re-)started after a recieved byte on the UART. So the last bytes in the buffer are send after a few ticks. But sometimes there are delays which are a lot longer than the timer should be.
    static uint8_t index = 0;
    uint32_t       err_code;
    switch (p_event->evt_type)
      // event is called when timer expiers
    		  case APP_CLEAR_BUFFER:
    				  //copy of APP_UART_DATA_READY without getting byte from UART --> no new byte there...
            if (index != 0)
                NRF_LOG_DEBUG("Ready to send data over BLE NUS\r\n");
                do
                    err_code = ble_nus_string_send(&m_nus, data_array, index);
                    if ( (err_code != NRF_ERROR_INVALID_STATE) && (err_code != NRF_ERROR_BUSY) )
                } while (err_code == NRF_ERROR_BUSY);
                index = 0;
    		case APP_UART_DATA_READY:
    Any idea what causes this delay?
  • Hi Hermann
    Have you modified the UART driver to do the timeout internally?
    It's hard to say why the problem occurs, but I assume it is related to how the app_timer callback is reset if you receive more data before the timeout should occur.
    I think it would be simpler from a logical standpoint to use a repeated timer instead, and check the state of the buffer in the timer, sending a packet if the buffer contains more than 0 bytes.
    Best regards
    Torbjørn
  • Hello, do you have news fr this post? thank you
  • Hi
    Is that a question for me or Hermann?
    Since he hasn't responded to the case I consider it resolved.
    If you have a related UART issue I recommend opening a new ticket.
    Best regards
    Torbjørn
