Hi
I use SDK version 12.2.0 to do a project. I add two 128bit uuid into my project. The one of 128bit uuid is created by myself. The other one of 128bit uuid is used ancs by SDK 12.2.0. I have a problem to get information that error code (0x18) when I call sd_ble_enable.
I tried some test for this condition. I removed ancs service(only use my created service). I set parameter as below and it works.
memset(p_ble_enable_params, 0, sizeof(ble_enable_params_t));
p_ble_enable_params->common_enable_params.vs_uuid_count = 1;
p_ble_enable_params->gatts_enable_params.attr_tab_size = SOFTDEVICE_GATTS_ATTR_TAB_SIZE;
p_ble_enable_params->gatts_enable_params.service_changed = SOFTDEVICE_GATTS_SRV_CHANGED;
p_ble_enable_params->gap_enable_params.periph_conn_count = 1;
p_ble_enable_params->gap_enable_params.central_conn_count = 0;
On the other hand, I tried to remove a service that create by myself(only use ancs service). I use parameter as below, it also works.
p_ble_enable_params->common_enable_params.vs_uuid_count = 10;
I merged both of service into a project. I used parameter as below. It has failure of sd_ble_enable err_code (0x12).
p_ble_enable_params->common_enable_params.vs_uuid_count = 11;
p_ble_enable_params->gap_enable_params.periph_conn_count = 2;
I have no idea. Could you help me to solve this problem? Or tell me what I can do. Thanks.
This is my log for three conditions.
Only add BLE_ANCS_C LOG:
[APP_BUTTON]:INFO:app_button_enable ++++
[APP_BUTTON]:INFO:pin_no = 17
[APP_BUTTON]:INFO:pin_no = 18
[APP_BUTTON]:INFO:pin_no = 19
[APP_BUTTON]:INFO:pin_no = 20
CLOCK:INFO:Function: nrf_drv_clock_init, error code: NRF_SUCCESS.
SDH:INFO:[JOHNLIN][softdevice_enable]: vs_uuid_count = 1, service_changed = 0, periph_conn_count = 1, central_links_count = 0
APP:INFO:[ble_stack_init]: vs_uuid_count = 10, service_changed = 0, periph_conn_count = 1, central_links_count = 0
SDH:INFO:[softdevice_enable]: RAM start at 0x20002078
SDH:INFO:[softdevice_enable]: err_code = 0
SDH:INFO:[softdevice_enable]: vs_uuid_count = 10, service_changed = 0, periph_conn_count = 1, central_links_count = 0
APP:INFO:[softdevice_ble_evt_handler_set]: err_code = 0
APP:INFO:[softdevice_sys_evt_handler_set]: err_code = 0
UFIT_SERVICE:INFO:[db_discovery_init] err_code = 0
UFIT_SERVICE:INFO:[ancs_init] err_code = 0
APP:INFO:BLE ANCS Started
UFIT_SERVICE:INFO:Connected.
UFIT_SERVICE:INFO:Disconnected.
Only BLE_UFIT SERVICE LOG:
SDH:INFO:[softdevice_enable]: vs_uuid_count = 1, service_changed = 0, periph_conn_count = 1, central_links_count = 0
APP:INFO:[ble_stack_init]: vs_uuid_count = 1, service_changed = 0, periph_conn_count = 1, central_links_count = 0
SDH:WARNING:sd_ble_enable: RAM start should be adjusted to 0x20001fe8
SDH:WARNING:RAM size should be adjusted to 0x6018
UFIT_SERVICE:INFO:[ufit_init] err_code = 0
Both of UUID 128bit services LOG:
SDH:INFO:[softdevice_enable]: vs_uuid_count = 1, service_changed = 0, periph_conn_count = 2, central_links_count = 0
APP:INFO:[ble_stack_init]: vs_uuid_count = 11, service_changed = 0, periph_conn_count = 2, central_links_count = 0
SDH:INFO:[softdevice_enable]: err_code = 18
SDH:INFO:[softdevice_enable]: vs_uuid_count = 11, service_changed = 0, periph_conn_count = 2, central_links_count = 0
SDH:ERROR:sd_ble_enable: error 0x12
APP_ERROR:ERROR:Fatal
