Hej, I just spent plenty of time finding an answer on above error within here with no luck. Since there are certainly others facing this problem, I hereby post my solution for reference:
Segger Embedded Studio (SES) has caught my attention and so I ported the
examples\ble_peripheral\experimental_ble_nfc_pairing_reference\
from SDK 13. After solving startup, flash placements and all the other subtleties, I got following linker error:
Output/nrf52832_xxaa/Exe/ble_nfc_pairing_reference_pca10040_s132.elf section
i.halNfcCallback' will not fit in region
UNPLACED_SECTIONS'
Using objdump -h nfc_t2t_lib_keil.lib
and objdump -h nfc_t2t_lib_gcc.a
revealed that
the keil-library requires two additional sections the gcc-library doesn't:
In archive nfc_t2t_lib_keil.lib:
nfc_t2t_lib.o: file format elf32-little
Sections:
Idx Name Size VMA LMA File off Algn
0 i.halNfcCallback 0000009c 00000000 00000000 00000034 2**2
CONTENTS, ALLOC, LOAD, RELOC, READONLY, CODE
23 .constdata 0000000a 00000000 00000000 00000775 2**0
So what you need to do is add two new sections to your flash_placement.xml file:
<ProgramSection alignment="4" load="Yes" name="i" />
<ProgramSection alignment="4" load="Yes" name=".constdata" />
additional note: I found no reference in any KEIL-project files in the SDK and hence assume that these two sections are builtin-standard-KEIL sections. nfc t4t library, gazell library and others may also require manual addition of these two sections in SES.
