I am specific about master as I have to connect two simultaneously(obviously to two different pins pair). Plz provide any code outline if you have, Thank you in Advance
Why do you need to connect the devices to different pin pairs? The TWI bus can interface multiple devices using addresses.
I want them(two i2c masters) to work simultaneously. As I need a higher data transfer rate
Given that you use SDK version 12.0.0 or higher, the following twi_init should work:
/* TWI PIN numbers. */
#define SCL_PIN_1 26
#define SDA_PIN_1 27
#define SCL_PIN_2 28
#define SDA_PIN_2 29
/* TWI instance ID. */
#define TWI_INSTANCE_ID_1 0
#define TWI_INSTANCE_ID_2 1
/* TWI instance. */
static const nrf_drv_twi_t m_twi_1 = NRF_DRV_TWI_INSTANCE(TWI_INSTANCE_ID_1);
static const nrf_drv_twi_t m_twi_1 = NRF_DRV_TWI_INSTANCE(TWI_INSTANCE_ID_2);
* @brief TWI initialization.
void twi_init (void)
ret_code_t err_code;
const nrf_drv_twi_config_t twi_1_config = {
.scl = SCL_PIN_1,
.sda = SDA_PIN_1,
.frequency = NRF_TWI_FREQ_100K,
.interrupt_priority = APP_IRQ_PRIORITY_HIGH,
.clear_bus_init = false
const nrf_drv_twi_config_t twi_2_config = {
.scl = SCL_PIN_2,
.sda = SDA_PIN_2,
err_code = nrf_drv_twi_init(&m_twi_1, &twi_1_config, twi_handler_1, NULL);
err_code = nrf_drv_twi_init(&m_twi_2, &twi_2_config, twi_handler_2, NULL);
nrf_drv_twi_enable(&m_twi_1);
nrf_drv_twi_enable(&m_twi_2);
Note that you need to enable two TWI interfaces in sdk_config.h:
#define TWI0_ENABLED 1
#define TWI1_ENABLED 1
Jørgen
thank you so much Jorgen
