[Aim] I am working on a project where I aimed to Integrate/Develop firmware management system using Contiki running over Nordic NRF52.
[Components] Contiki running over Nordic NRF52 + LwM2M (Management server) + CoAP block transfer (Transport Medium) + IoT DFU (Nordic's library to storing firmware into flash memory).
[Work Done] I can successfully run LwM2M and CoAP block transfer on Contiki running over Nordic NRF52 and struggling with Nordic's IoT DFU Contiki. I integrated the IoT DFU module (pstorage_raw) with Contiki application and trying to simply write and read into flash memory.
[Problem] For a start I wrote boot loader setting with sample firmware size .. crc ..etc (precisely the work done by "iot_dfu_firmware_apply()" in IoT DFU library). I did the initialization of nrf memory, pstorage and IoT DFU using their specified calls. The given logs shows that bootloader file was opened and written successfully but I never received the "IOT_DFU_WRITE_COMPLETE" callback from lower layer. Also if I am going to read the same setting again using "iot_file_fread()" it throws an error 45841.
[Debug Logs]
[IOT_DFU]: >> iot_dfu_init
[IOT_DFU]: << iot_dfu_init
[APPL]: Update Softdevice with Application.
[IOT_DFU]: >> iot_dfu_firmware_apply
[IOT_DFU]: Update SoftDevice upgrade status.
[IOT_DFU]: Update Application upgrade status.
[FILE][PSRaw] >> fopen.
[FILE][PSRaw]: FLASH file initialization.
[FILE][PSRaw] << fopen.
[FILE][PSRaw] >> fwrite.
[FILE][PSRaw]: ALLOC buffer.
[FILE][PSRaw] << fwrite.
[IOT_DFU]: << iot_dfu_firmware_apply
Note: It seems in contiki port for NRF52 there is a pstorage_platform.h file already given (platform/nrf52dk/config/pstorage_platform.h) however I am using the pstorage_platform.h given for IoT DFU application in Nordic IoT 9 SDK.
Any sort of support/suggestion would be appreciated. Also let me know if any other information is required.
