I am running the ble_app_uart example in SDK 13.0 with nRF52382.
- First issue
The app can receive data via UART only when I use "Termite" as a terminal emulator. If I use "TeraTerm", "Putty" and "RealTerm" to send data, it seems that APP_UART_DATA_READY event is not occured in uart_error_handle()
- Second issue
I configured the app to use even parity as follows.
static void uart_init(void)
uint32_t err_code;
const app_uart_comm_params_t comm_params =
.rx_pin_no = RX_PIN_NUMBER,
.tx_pin_no = TX_PIN_NUMBER,
.rts_pin_no = RTS_PIN_NUMBER,
.cts_pin_no = CTS_PIN_NUMBER,
//.use_parity = false,
.use_parity = true,
.baud_rate = UART_BAUDRATE_BAUDRATE_Baud115200
The terminal emulator setting was changed to even parity. Then, I tried to send data via UART from it, the app was rebooted. Even if I used "Termite" as a terminal emulator, it happened.
I would appreciate if you could give me any advice.
