I am running MCP9808 on NRF52 EVB, i have this following program which is not giving the correct values on terminal display
I have this program running on KEIL 5, what could be the problem with the code and Do you guys have any sample code for mcp9808? Note- I am using the wired connection not a Bluetooth app to sense the temperature Please Help Thank you!
#include <stdio.h>
#include "boards.h"
#include "app_error.h"
#include "nrf_drv_twi.h"
#include "nrf_delay.h"
//#define NRF_LOG_MODULE_NAME "APP"
#include "nrf_log.h"
#include "nrf_log_ctrl.h"
/* TWI instance ID. */
 #define TWI_INSTANCE_ID     0
#define TWI_ADDRESSES      127
/* Common addresses definition for temperature sensor. */
//#define MCP_9808_ADDR          (0x18)
//#define MCP_9808_REG_TEMP      0x00U
//#define MCP_9808_REG_CONF      0x01U
//#define MCP_9808_REG_THYST     0x02U
//#define MCP_9808_REG_TOS       0x03U
#define SCL_PIN             28
#define SDA_PIN             29
//#define MCP_9808_REG_RFU     0x00U
//#define MCP_9808_REG_TUPPER  0x02U
//#define MCP_9808_REG_TLOWER  0x03U
//#define MCP_9808_REG_TCRIT   0x04U
//#define MCP_9808_REG_TEMP      0x05U
//#define MCP_9808_REG_MID       0x06U3
//#define MCP_9808_REG_DID       0x07U
//#define MCP_9808_REG_RESR    0x08U
/* Mode for MCP_9808. */
#define NORMAL_MODE 0U
//#define MCP9808_REG_UPPER_TEMP         0x02
//#define MCP9808_REG_LOWER_TEMP         0x03
//#define MCP9808_REG_CRIT_TEMP          0x04
#define MCP9808_REG_AMBIENT_TEMP         0x05
//#define MCP9808_REG_MANUF_ID           0x06
//#define MCP9808_REG_DEVICE_ID          0x07
/* Indicates if operation on TWI has ended. */
static volatile bool m_xfer_done = false;
/* TWI instance. */
static const nrf_drv_twi_t m_twi_mcp9808 = NRF_DRV_TWI_INSTANCE(TWI_INSTANCE_ID);
/* Buffer for samples read from temperature sensor. */
static uint16_t m_sample;
 * @brief Function for setting active mode on MMA7660 accelerometer.
void MCP_9808_set_mode(void)
   ret_code_t err_code;
    /* Writing to MCP_9808_REG_CONF "0" set temperature sensor in NORMAL mode. */
			uint8_t reg[2] = {MCP_9808_REG_CONF, NORMAL_MODE};
			err_code = nrf_drv_twi_tx(&m_twi_mcp9808, MCP_9808_ADDR, reg, sizeof(reg), false);
			while (m_xfer_done == false);
			/* Writing to pointer byte. */
			reg[0] = MCP9808_REG_AMBIENT_TEMP;
 * @brief Function for handling data from temperature sensor.
 * @param[in] temp          Temperature in Celsius degrees read from sensor.
__STATIC_INLINE void data_handler(uint32_t temp)
	union
float floatVal;
uint32_t bytes[4];
} floatConverter;
    floatConverter.bytes[0]=0x02;
    floatConverter.bytes[1]=0x03;
    floatConverter.bytes[2]=0x04;
    floatConverter.bytes[3]=0x05;
float eepromFloat = floatConverter.floatVal;
 // NRF_LOG_INFO("Temperature: %x  degree Celsius.\r\n", floatConverter.bytes[3]);
	  NRF_LOG_INFO("Temperature: %d  degree Celsius.\r\n",temp);
		//NRF_LOG_INFO("TWI device detected at address 0x%x.\r\n", address);
 * @brief TWI events handler.
void twi_handler(nrf_drv_twi_evt_t const * p_event, void * p_context)
    switch (p_event->type)
        case NRF_DRV_TWI_EVT_DONE:
            if (p_event->xfer_desc.type == NRF_DRV_TWI_XFER_RX)
                data_handler(m_sample);
            m_xfer_done = true;
 * @brief UART initialization.
void twi_init (void)
    const nrf_drv_twi_config_t twi_mcp9808_config = {
			 .scl              	 = SCL_PIN,
       .sda                = SDA_PIN,
       .frequency          = NRF_TWI_FREQ_100K,
       .interrupt_priority = APP_IRQ_PRIORITY_HIGH,
       .clear_bus_init     = false
    err_code = nrf_drv_twi_init(&m_twi_mcp9808, &twi_mcp9808_config, twi_handler, NULL);
    nrf_drv_twi_enable(&m_twi_mcp9808);
 * @brief Function for reading data from temperature sensor.
static void read_sensor_data()
    /* Read 1 byte from the specified address - skip 3 bits dedicated for fractional part of temperature. */
  // ret_code_t
	err_code = nrf_drv_twi_rx(&m_twi_mcp9808, MCP_9808_ADDR, (uint8_t*)&m_sample, sizeof(m_sample));
    NRF_LOG_INFO("\r\nTWI sensor reading\r\n");
    NRF_LOG_FLUSH();
    twi_init();
    MCP_9808_set_mode();
    while (true)
        nrf_delay_ms(1000);
        do
            __WFE();
        }while (m_xfer_done == false);
        read_sensor_data();
        NRF_LOG_FLUSH();
