When I test the timer example with nrf52832 DK, it so nice to 4 minutes.
uint32_t time_ms = 240000;
But when I set the time interval over 5 minutes, then the event handler run more rapidly.
So, what should I do for long time period?
Hi JW,
By default, the timer runs at 16 MHz and the maximum bit width of the timer is 32-bit. This corresponds to a maximum timer value of:
(2^32)-1 = 4294967295
The reason why you see event handler more rapidly with 5 minutes, is that nrf_drv_timer_ms_to_ticks
use the configured frequency and the time_ms
parameter to generate the number of ticks, and return this in a 32 bit variable:
5*60*16000000 = 4800000000
This overflows the 32 bit variable, giving you a tick count of 505032705 = ~31.5 seconds.
You need to change the frequency of the timer to make it run run slower. This is done by changing the timer configuration:
timer_cfg.frequency = NRF_TIMER_FREQ_8MHz;
You can set it to any of the frequencies documented here.
Jørgen
Hello Jørgen,
Thank you for answering my question. I can understand the timer configuration by your explanation.
But when I changed the frequency on 'nrf_drv_config.h'
from 16MHz
#define TIMER0_ENABLED 1
#if (TIMER0_ENABLED == 1)
#define TIMER0_CONFIG_FREQUENCY NRF_TIMER_FREQ_16MHz
#define TIMER0_CONFIG_MODE TIMER_MODE_MODE_Timer
#define TIMER0_CONFIG_BIT_WIDTH TIMER_BITMODE_BITMODE_32Bit
#define TIMER0_CONFIG_IRQ_PRIORITY APP_IRQ_PRIORITY_LOW
#define TIMER0_INSTANCE_INDEX 0
to 8MHz
#define TIMER0_CONFIG_FREQUENCY NRF_TIMER_FREQ_8MHz
and set the timer interval 1 second
uint32_t time_ms = 1000;
nothing changed.
The timer event handler run every 1 second at both configuration.
Your observations are correct, this change will not affect the time between event handler calls. What it will change is the output from nrf_drv_timer_ms_to_ticks()
, the variable time_ticks
. With time_ms = 1000
and frequency set to 16 MHz, the returned value will be 16 000 000. With time_ms = 1000
and frequency set to 8 MHz, it will return 8 000 000. Reducing the frequency will reduce the resolution of the timer, but it will increase the time the timer can run before overflowing.
Well, but when I set the time interval 5 minutes with time_ms = 300000
after change frequency to 8MHz, the event handler also run every 30 seconds.
I see there is a 32 bit multiplication inside the function, resulting in the return value being wrong. If you change line 618 in nrf_timer.h from return ((time_ms * 16000UL) >> prescaler);
to return ((time_ms * 16000ULL) >> prescaler);
, you should get correct behavior.
