Wake-up source with nRF52 capacitive touch and current consumption
Hello, I'm planning to try the NordicBlog; Capacitive Touch on the nRF52 series to test a button type or a up-down slider type.
I'm planning to use an nRF52832-QFAA for a new 2 layered FR-4 PCB.
My application will be based on the UART service example, so it will use S132 SoftDevice.
These are my questions;
  1. Before starting my questions, I wish to check the blog's notice;
The blog introduced 2 ways.
1. Resistor capacitor (RC) charge timing.
2. Relaxation oscillator (RO).
However,
Due to erratum 84 (COMP: ISOURCE not functional),
capacitive sensing using the relaxation oscillator method is not usable in a real product
with the nRF52832, as it will only work reliably in room temperature.
Then, if I choose the RC charge timing method,
Two pins are required per button:
- one GPIO output pin for charging the sensor capacitor via a large resistor (e.g. 1–10 MΩ).
- one analog input pin connected to the sensor electrode at the same point as the GPIO
(without the resistor). This is used to measure the voltage over the sensor capacitor.
I need 2 pins (GPIO output pin & Analog input pin) per button to use that method and this is feasible in other temperatures, right?
  1. I hope that the capacitive touch button can be an input that can wake the nRF52 from the System OFF mode or the sub power (low power, by calling sd_app_evt_wait) mode.
    The device can be put into System OFF mode using the POWER register interface. When in System OFF mode, the device can be woken up through one of the following signals:
    1. The DETECT signal, optionally generated by the GPIO peripheral
    2. The ANADETECT signal, optionally generated by the LPCOMP module (OMITTED OTHER OPTIONS)
Since the RC charge timing method uses an analog input pin, I wish to infer that this satisfies option 2 (ANADETECT signal) to wake the nRF52 from System OFF mode.
(PLEASE NOTE THAT I SAID INFER)
Then, by touching a button type capacitive touch or sliding the slide type touch sensor,
can this make the nRF52 to wake up from System OFF mode or low power mode?
  1. The blog didn't notice about power consumption while using capacitive touch sensors.
This is my concern while creating a product that uses a 1000mAh Li-Po battery;
  • should I add other vendor's capacitive touch solution that claims that it uses less than a µA?
  • Or should I lower the material cost even though the nRF52 consumes heavy currents (if it really does, maybe more than 2mA per button? So I really hope not) while using its capacitive touch solution?
Suppose I created 2 circle shape button type touch sensors that use the RC charge timing method, have the radius of 10mm, and connected 10MΩ resistor at the GPIO output.
Let's say that these are created on a 1.6mm thick 2 layered FR-4 PCB that has nRF52832-QFAA.
If I know the size of the touch sensor and the resistor value, can I estimate the current consumption caused by the touch sensors?
Too bad that the new Nordic Thingy52 doesn't have a capacitive touch sensor.
I would have plugged that to my power consumption measuring device if the Thingy52 had that.
-Best Regards, MANGO
  • Hi Mango,
    you will not be able to wake the nRF52832 up from System OFF since in this state only the wake-up circuitry (GPIO DETECT mechanism, LPCOMP and NFC Sense mechanism) is active.
    This means that you will not be able to source any current from the GPIO pins or use the TIMER peripheral to perform measurements while the nRF52832 is in System OFF mode.
    Waking the nRF52832 up from System ON: Low power mode should not be an issue.
    As for the current consumption, we have not done any measurements on this, but since you're using the TIMER peripheral, which requires the HFCLK, then you're going to see a run current of at least 250uA (HFCLK run current) + 70uA ( TIMER run current @ 16MHz) = 320uA.
  • Hi, Bjørn. Thanks for your profound answer!
    • About the 320µA, this is not proportional regardless of the number of touch buttons, right?
    For instance, if 4 buttons are used, the HFCLK run current is same but the timer run current should be multiplied, I guess? 250µA + 70*4µA = 530µA?
    To be sure, the best answer will be the measured value after creating the PCB.
    I just want to estimate before creating one.
    -Best Regards
  • No, the nEF51 capsense example only uses one TIMER instance, so the TIMER run current does not need to be multiplied with the total number of buttons.
