Arm Gcc (using Eclipse Neon) | SDK 13.0 | nrf52 DK (PCA10040) | tried soft device 4.0.2 and 4.0.4
I can successfully compile and run the example -ble peripheral- ble_app_hrs. Everything works as it should including bonding.
I want to add concurrent connections (nrf is peripheral - nrf has no central). I am referencing the experimental multiperipheral example (which works and compiles fine on its own - just no bonding or peer manager). When I change the following lines in the ble_app_hrs example, I get error 4 on softdevice_enable.
Under // Configure the maximum number of connections , I change the default to:
ble_cfg.gap_cfg.role_count_cfg.periph_role_count = 2;
I think error 4 means a memory error. So I put some breakpoints in softdevice_handler.c where it throws error 4 and get the correct memory origin (original was 0x20002558, it now says it should be 0x20002c98. I change the linker to have the origin as 0x20002c98 instead of 0x20002558. I clean the project and erase the chip and recompile and flash and the program does not start. When I go to debug, I get an 0x0 error window open in the debugger and the program never starts.
What am I missing? Any help would be appreciated! Bryan
