Could not determine GDB version after sending...
After quite a few difficulties getting Keilv5 to work with the included examples with no responses (devzone.nordicsemi.com/.../) I decided to give Eclipse a shot.
This tutorial was helpful, except that it's a bit out-dated for Eclipse Oxygen. devzone.nordicsemi.com/.../
I used this super helpful article to fill the gaps mcuoneclipse.com/.../
Good news is.. everything builds without errors! Bad news is that I can't initiate a debug session after a version check, and I have some questions on how to flash both the application and soft device using this interface.
  1. Version check issue When running Debug, with "executable" set to the ARM GDB directory, I get the following error - presumably because it's trying to check the version and can't parse the output:
    Could not determine GDB version after sending: F:\Program Files (x86)\6 2017-q2-update\bin\arm-none-eabi-gcc --version, response: arm-none-eabi-gcc (GNU Tools for ARM Embedded Processors 6-2017-q2-update) 6.3.1 20170620 (release) [ARM/embedded-6-branch revision 249437] Copyright (C) 2016 Free Software Foundation, Inc. This is free software; see the source for copying conditions. There is NO warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
Is there any work-around to this? How do I disable version checks, or can I use an older GDB instance?
2)Flashing the SoftDevice The tutorial states "For the heart rate or other BLE examples you will need to flash the softdevice by executing the "flash_softdevice" target." which is less than helpful.
I see the makefile includes "flash_softdevice", but how do I actually get the debugger to run those commands via the flash tool? Thanks, Andrew
