hi, I used gpiote to capture an external interrupt when I found an anomaly. I configured the interrupt input io, burn the program can be normal operation, when I power down the device, and then re-power, found that the equipment is not working properly. At this point I need to press the reset button, the program will run normally
nrf_drv_gpiote_in_config_t in_config = GPIOTE_CONFIG_IN_SENSE_LOTOHI(false);
in_config.pull = NRF_GPIO_PIN_PULLUP;
err_code = nrf_drv_gpiote_in_init(BUTTON_1, &in_config, in_pin_handler);
