Hi everyone,
I am writing a program in Keil whereby I have to send a large amount of data through BLE notification in real time. The program works by having two timers, one timer is used for the ADC to sample at 400Hz, so every 2.5ms, the other timer is used to see if the data is ready to be sent to the phone. The other timer scans every 1ms and sends the data on every 100 samples, so every 250ms. There are 6 ADC channels being sampled each time and each channel requires 2 bytes of storage so in total 12 bytes per sample. Therefore 1200 bytes are sent on every notification or every 250ms. However this notification is only ever switched on for a couple of seconds for data verification purposes.
This means a throughput of at least 4800 bytes is required however the current throughput is below this as I am losing packets. Below is my code for sending the notification, is there anyway of sending more packets or is it better for me to use a large array to hold the data for a couple of seconds then send them all at once instead of sending data every 250ms.
Below is my function for sending the notification
void timer_timeout_handler2()
if( (new_data == true) && (notification_enabled == true) )
for(int i=0; i<MAX_NUMBER_OF_SAMPLES; i++)
ble_cus_custom_value_update(&m_cus, data+2*NUMBER_OF_ADC_CHANNELS*i);
new_data = false;
Right now it is calling the notification function 100 times to send 100 samples worth of data every time the ADC has finished sampling 100 times. (MAX_NUMBER_OF_SAMPLES = 100), (NUMBER_OF_ADC_CHANNELS = 6). I do not know how the packets are packaged or whether this is the correct way of sending the data, as data array is only 12 bytes long instead of 20 for maximum throughput due to how data is process on the clients side. But maybe the softdevice is splitting the data into 20 byte chunks? Also from the datasheet it seems like only 6 packets can be sent per connection interval so I do not know how it handles sending the 100 samples, is each sample of 12 bytes treated as a packet? Is there anyway of spacing the data evenly? As right now on the client side I would get the data in chunks which I am presumed is due to the data being split across multiple connection intervals, however not all data can be sent before the ADC has finished sampling another 100 samples, hence the lost of packet. What would be a better way of implementing this?
Thanks for the help
Rgs, Bryan
