I am trying to use read/write authorisation on a characteristic in order to get/set a connection specific value of a characteristic
I am am having issues getting the new characteristic value from the BLE_GATTS_AUTHORIZE_TYPE_WRITE event
I write a value, for example 0x2FCD1000 using the NRF Connect app but when I read it, I receive a value with the top two bytes wrong, for example 0x2FCDD484
my function for handling a BLE_GATTS_EVT_RW_AUTHORIZE_REQUEST event is as follows
static void on_rw_auth_request(ble_my_data_t * p_my_data, ble_evt_t * p_ble_evt)
ble_gatts_evt_rw_authorize_request_t req = p_ble_evt->evt.gatts_evt.params.authorize_request;
if(req.type == BLE_GATTS_AUTHORIZE_TYPE_READ &&
( req.request.read.handle == p_my_data->my_char_handles.value_handle))
ble_gatts_rw_authorize_reply_params_t auth_reply;
auth_reply.type = BLE_GATTS_AUTHORIZE_TYPE_READ;
auth_reply.params.read.gatt_status = BLE_GATT_STATUS_SUCCESS;
auth_reply.params.read.update = 0;
auth_reply.params.read.offset = 0;
auth_reply.params.read.len = sizeof(p_my_data->my_char);
auth_reply.params.read.p_data = (uint8_t*)&p_my_data->my_char;
sd_ble_gatts_rw_authorize_reply(p_ble_evt->evt.gatts_evt.conn_handle, &auth_reply);
else if(req.type == BLE_GATTS_AUTHORIZE_TYPE_WRITE &&
( req.request.write.handle == p_my_data->my_char_handles.value_handle))
TRACE("WRITE\r\n");
TRACE("HANDL %d\r\n", req.request.write.handle);
TRACE("OFFSET %d\r\n", req.request.write.offset);
TRACE("LEN %d\r\n", req.request.write.len);
memset(&auth_reply, 0, sizeof(auth_reply));
auth_reply.type = BLE_GATTS_AUTHORIZE_TYPE_WRITE;
auth_reply.params.write.update = 1;
if(req.request.write.len == sizeof(p_my_data->my_char))
p_my_data->my_char = *(uint32_t *)req.request.write.data;
TRACE("DATA 0x%x\r\n", p_my_data->my_char);
auth_reply.params.write.gatt_status = BLE_GATT_STATUS_SUCCESS;
auth_reply.params.write.offset = req.request.write.offset;
auth_reply.params.write.len = req.request.write.len;
auth_reply.params.write.p_data = req.request.write.data;
auth_reply.params.write.gatt_status = BLE_GATT_STATUS_ATTERR_INVALID_ATT_VAL_LENGTH;
uint32_t err_code = sd_ble_gatts_rw_authorize_reply(p_ble_evt->evt.gatts_evt.conn_handle, &auth_reply);
TRACE("ERR %d\r\n", err_code);
ble_gatts_value_t p_value;
uint32_t d;
p_value.len = 4;
p_value.offset = 0;
p_value.p_value = (uint8_t*)&d;
err_code = sd_ble_gatts_value_get(p_ble_evt->evt.gatts_evt.conn_handle, req.request.write.handle, &p_value);
TRACE("GET 0x%x\r\n", d);
The trace is as follows
- WRITE
- HANDL 19
- OFFSET 0
- LEN 4
- DATA 0x84D4CD2F
- ERR 0
- ERR 0
- GET 0x84D4CD2F
what am I doing wrong? The characteristic is set up to have a length of 4 bytes and it works perfectly when I don't enable read/write authorisation
I'm using an NRF52 S332 and SDK13.0
