0
How to test Bidirectional data transfer between each PTX and the PRX
suker.su gravatar image
asked 2017-08-10 11:28:57 +0200
1,NRF52832 2,use ESB code 3,I want to do a transport data from PRX to PTX
edit retag flag offensive close delete report spam
1 answer
Sort by » oldest newest most voted
0
ovrebekk gravatar image
answered 2017-08-11 16:14:02 +0200
Hi
You send data from the PRX to the PTX in almost the same way as you send data from the PTX.
You use the same function, but you have to pre-load the packet to be sent. Then the packet will be sent to the PTX as a part of the ACK on the next packet the PTX sends to the PRX.
If you upload the packet beforehand it will simply be queued in the FIFO, and then it will be sent as soon as you receive something from the PTX.
If you use the SDK ESB example as a starting point it should be relatively quick to modify it so that the PRX sends data in return to the PTX.
Best regards
Torbjørn
edit flag offensive delete publish link more
Your Answer
Please start posting anonymously - your entry will be published after you log in or create a new account.
Add Answer. Do not ask a new question or reply to an answer here.
[hide preview]
Question Tools
1 follower
Stats
Asked: 2017-08-10 11:28:57 +0200
Seen: 21 times
Last updated: Aug 11
