connect interval
SDK: nRF5_SDK_11.0.0 Softdevice: s132_nrf52_2.0.0_softdevice
#define MIN_CONN_INTERVAL               MSEC_TO_UNITS(20, UNIT_1_25_MS)             /**< Minimum acceptable connection interval (20 ms), Connection interval uses 1.25 ms units. */
#define MAX_CONN_INTERVAL               MSEC_TO_UNITS(20, UNIT_1_25_MS)             /**< Maximum acceptable connection interval (75 ms), Connection interval uses 1.25 ms units. */
In the program I set the maximum minimum connection interval of 20ms, and then use the Android to connect the device, but in my capture of the Broadcast packets: ADV_CONNECT_REQ - LLData - Interval - 0x0028, Calculate the connection interval is 50ms, by observing the following data packet found that the connection event interval is 50ms. I know the connection interval decision is the phone, but the phone can set the connection interval beyond the setting range of the slave?
  • Please use the code button, otherwise the hash tag makes the code into a heading
    When initializing the Connection Parameters module you have the option to decide if a failed connection parameters update shall cause an automatic disconnection or not. This is done by setting the disconnect_on_fail flag. A connection parameters update is here considered failed if the central and peripheral have not agreed upon the connection parameters after MAX_CONN_PARAMS_UPDATE_COUNT number of connection parameter update attempts.
    Code snippet:
        ret_code_t             err_code;
        cp_init.start_on_notify_cccd_handle    = m_hrs.hrm_handles.cccd_handle;
    Note that you will get a BLE_CONN_PARAMS_EVT_FAILED event after a failed connection parameters update. This allows you to directly disconnect, and/or take other actions in the Connection Parameters event handler, even if you have set the disconnect_on_fail flag to false.
    Code snippet:
