freertos & logging
Hi All,
I would like to use FreeRTOS in my project. I try to play with the examples/ble_peripheral/ble_app_hrs_freertos project.
I have enabled logging with RTT. The program is working well, I can connect with JLinkRTTClient and I have seen log messages. And when I try to logging in a task ble_stack_thread function for example the first line of function:
NRF_LOG_INFO("Task started\r\n");
it goes to HardFault_c_handler with address 0x20002db8. When I comment this log messages it works well.
It seems to be some problem with FreeRTOS and logging.
I changed port_cmsis_systick.c as suggested here: devzone.nordicsemi.com/.../
I use Debian Linux/Eclipse and SDK version is: nRF5_SDK_12.3.0_d7731ad
thnx Zamek
  • HI Zamek, could you test this with the latest release of the SDK, i.e. SDK v14.0.0 and see if this is still an issue?
  • Hi Bjorn,
    I downloaded the nRF5_SDK_14.0.0_3bcc1f7, but in this example contains only one task, which is the logging task:( The ble funcionality doesn't run in a task. It should be good. And I make a new task like this:
    #if NRF_LOG_ENABLED
        // Start execution.
        if (pdPASS != xTaskCreate(logger_thread, "LOGGER", 256, NULL, 1, &m_logger_thread))
            APP_ERROR_HANDLER(NRF_ERROR_NO_MEM);
        if (pdPASS != xTaskCreate(alive_thread, "alive", 256, NULL, 1, &m_alive_thread))
    and the task code is like this:
    static void alive_thread(void *arg)
    	UNUSED_PARAMETER(arg);
    	int i=0;
    	for(;;) {
    		bsp_board_led_invert(BSP_BOARD_LED_2);
    		vTaskDelay(500);
    		if (++i<10)
    			continue;
    		i=0;
    		NRF_LOG_INFO("tick\r\n");
    Unfortunately I got the next message in serial console:
    <error> nrf_sdh_freertos: SoftDevice task not created.
    <error> app: Fatal
    I used make flash_softdevice and make flash.
    thx, Zamek
